[Mapbender-users] Mapbender 2.7.4
lukas.bollack lukas.bollack at naturnetz.ch
Tue Feb 9 02:07:28 PST 2016
Hi Armin
Thanks! Too bad there is only this way to do it! I don't want the features
to only be editable by the user who first created them. It should be more of
an information.
For the date I found out you can define this as a default value in the
postgis database, but it seems that geoserver won't respect the constraint
if you edit the layer via wfs.
I guess for the time being, the users will have to add their names and the
current date manually when they digitze something..
Regards
Lukas
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbender-2-7-4-tp5249641p5249659.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
