[Mapbender-users] Mapbender 2.7.4
Armin Retterath armin.retterath at gmail.com
Tue Feb 9 01:57:15 PST 2016
hi lukas,
you can use the auth column of wfs-conf to do a simple authorization. if
you fill in $_SESSION['mb_user_id'] e.g. mapbender automatically stores the
mb_user_id in this field. Those features can only be altered by this user.
other handlings have to be coded ;-)
armin
2016-02-09 10:20 GMT+01:00 lukas.bollack <lukas.bollack at naturnetz.ch>:
> Hi MapBender Mailing List!
> I was wondering if there is a way to automatically insert the username and
> current date into a feature dataset when you create or edit a feature
> dataset via wfs in the digitizer? I know you can define a default text for
> a
> textfield like this: <textarea cols='20' rows='5' id='anmerk'>default
> text</textarea> but can you also have mapbender fill it in depending on
> which user is logged in and what date it is?
> Regards
> Lukas
> http://osgeo-org.1560.x6.nabble.com/Mapbender-2-7-4-tp5249641.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160209/58033bc0/attachment.html>
More information about the Mapbender_users mailing list
