[Mapbender-users] Mapbender 2.7.4: A couple of questions
Armin Retterath
armin.retterath at gmail.com
Mon Feb 15 09:48:19 PST 2016
i forgot - for a dynamic overview there exists a special module with
further config options ;-)
http://www.mapbender2.org/DynamicOverview
2016-02-15 18:45 GMT+01:00 Armin Retterath <armin.retterath at gmail.com>:
> hi lukas,
> the styling of external wms only possible, if the wms support sld. in
> mapbender there is a sld editor to define a specific sld for a external
> wms. the problem is, that only very few wms support this user defined
> styling option.
> another possibility ist to use different styles - but even here only few
> wms support this feature.
> if a wms has more than one style, in the wms gui configuration you can
> select the style you want to use - or you can select the style in the
> layertree if this option is activated in treegde.
> yes - the bbox is pulled from the first wms which is in the gui. if you
> have to alter it, you may alter the bbox in the layer_epsg table directly.
> alternatively you can cascade a external wms with a local mapserver and
> register the local mapserver. in the configuration of the mapserver fascade
> you can alter the wms extent to your needs.
> a other possibility to start mapbender is to store a wms and start
> mapbender with giving the wmc as get parameter:
> http://www.mapbender2.org/GET-Parameter
> also bbox are supported - maybe this is an alternative ;-) .
> to alter a legend for a external wms you have also to edit the database
> directly :-( - the legends are stored in the layer_style table.
> if you have further questions don't hesitate to ask ;-)
> armin
> 2016-02-15 18:06 GMT+01:00 lukas.bollack <lukas.bollack at naturnetz.ch>:
>> Oh and another question:
>> How do I set the bounding box for my map window (mapframe1) as well as the
>> overview window (overview)? Does the module take this directly from the
>> bounding box of the background wms?
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Mapbender-2-7-4-A-couple-of-questions-tp5250589p5250595.html
>> Sent from the mapbender-users mailing list archive at Nabble.com.
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160215/958c3256/attachment.html>
More information about the Mapbender_users
