[Mapbender-users] Mapbender 2.7.4: How to rename jQuery tab elements
Jäger, Frank (KRZ) F.Jaeger at KRZ.DE
Tue Feb 16 06:30:49 PST 2016
Hi Lukas,
In „mapbender.conf“ file please set:
define("USE_I18N", true);          // requires gettext for PHP.
define("LANGUAGE", "de");     // only available if USE_I18N is "true"
While installing Mapbender please run:
  msgfmt locale/de_DE/LC_MESSAGES/Mapbender.po -o locale/de_DE/LC_MESSAGES/Mapbender.mo
in the resources-Folder.
Frank
Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Armin Retterath
Gesendet: Dienstag, 16. Februar 2016 15:19
An: Mapbender User List
Betreff: Re: [Mapbender-users] Mapbender 2.7.4: How to rename jQuery tab elements
hi lukas,
you don't need to store the title in german language ;-) . mapbender translate them automatically with its translation functions.
most titles and description which are defined in the source code is translated via gettext - there are translation files which can be adopted.
the translations for the tab titles and the helptexts for the client are defined in the mapbender database.
best regards
armin
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160216/174b2d56/attachment-0001.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160216/174b2d56/attachment-0001.bin>
More information about the Mapbender_users mailing list
