[Mapbender-users] Mapbender 2.7.4: How to rename jQuery tab elements
lukas.bollack
lukas.bollack at naturnetz.ch
Tue Feb 16 08:54:55 PST 2016
Ok I've tried to set up gettext but haven't finished yet - it's quite
complicated. Now in the end will I have to translate everything manually
anyway if I use gettext? Seems like a lot of work for the ~10 element names
i need changed right now.
Is there no other way to rename the Query elements? They are a bit enigmatic
anyway, I can't find them in the GUI customization window at all. How do I
change the location of theses elements for example, or how do I change which
of the elements show up in my GUI?
I would also like to change which tools show up in the digitizer tab. Do you
know how I can influence this?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbender-2-7-4-How-to-rename-jQuery-tab-elements-tp5250796p5250893.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users
