[Mapbender-users] Mapbender 2.7.4: Print Module
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Fri Feb 26 06:14:10 PST 2016
hi likas,
the printing is not possible with authenticated wms and without
owsproxy. you have to setup the owsproxy first:
http://www.mapbender2.org/Owsproxy#Apache_Konfiguration
please use the rewrite method (2.) ;-)
normally this should work. but if it don't - please ask :-) .
the 3. point is your problem :-( .
if nothing will work, it will be advisable to update to mapbender 2.8
(trunk). our geoportals of rhinland-palatinate, hesse and saarland work
on trunk without any problems. you can do an alternative installation
(svn checkout) into an other path and copy your current database (dump /
restore) . then update the copied database and alter the conf files
(mapbender.conf) to test the 2.8.
which os do you use?
best regards
armin
On 26.02.2016 14:31, lukas.bollack wrote:
> Hi Mapbender Mailing List
> I am trying to implement a printing function in my GUI. To this end I copied
> the elements "printPDF" and "printButton" from the "template_print" GUI into
> my own GUI. When I test the printing functionality it always times out "An
> error occured or timeout of 90 seconds reached. Print was aborted."
> Now when I use the print function inside of the "template_print" GUI it
> works fine and doesn't time out, so the module works on my server. When I
> add the wms from my own GUI to the "template_print" GUI, printing still
> works. I have 3 theories, what my problem could be:
> 1. There are some settings defined in the "printPDF" element I copied from
> the "template_print" GUI which refer to layers not present in my own GUI.
> 2. There is some element missing in my GUI which is needed for printPDF to
> work.
> 3. The base layer in my own GUI is password protected and I haven't
> succeeded in getting owsProxy to run yet. It works when I open my GUI in the
> browser but maybe the print module has problems accessing the WMS?
> Do any of you have an idea how I could solve this?
> Regards
> Lukas
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbender-2-7-4-Print-Module-tp5253023.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Von-Kuhl-Straße 49
56070 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users
