[Mapbender-users] Mapbender 2.7.4: Print Module
lukas.bollack
lukas.bollack at naturnetz.ch
Fri Feb 26 07:31:45 PST 2016
Hi Armin
I think it's more complicated than this. I found out that if I use the OSM
germany wms as a base map the printPDF module works. I also got it to work
with some other wms as base maps, but with others it didn't. In every case,
working or not, the password protected wms was present and displayed on the
map - I just didn't use it as the base map.
What's always the case when I use all my layers is that the module is
terribly slow. Maybe it's just a performance issue and that's why in some
cases the process times out and in others it doesn't?
Regards
Lukas
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbender-2-7-4-Print-Module-tp5253023p5253050.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users
