[Mapbender-users] MB 2.7.x: Can't save wms application settings
Armin Retterath armin.retterath at lvermgeo.rlp.de
Mon Jan 11 02:27:40 PST 2016
hi lukas,
1. the username/password is set in some fields below the registration
field of the url. you must set curl as connection method to use this
feature (http_digest and http_basic auth)
otherwise you will have the username and password in the javascript
client - which is not really senseful if you want to protect the service ;-)
2. this is a problem of the newer php versions 5.4+ - see:
http://www.mapbender2.org/Installation_de
increase max_input_vars in php.ini :-)
best regards from germany
armin
On 11.01.2016 11:08, lukas.bollack wrote:
> Hello Mapbender mailing list!
> I have the following problem with my mapbender 2.7.4 installation:
> I am trying to configure a wms service. I loaded the getcapabilities request
> into an empty gui. Since it is a password protected service, i used a
> request in the following form:
> http://user:password@url/wms?GetCapabilities&SERVICE=WMS&VERSION=1.1.0. When
> I use a request without username and password the wms can't be loaded and I
> am never asked for a username and password in the process.
> Then I linked the wms in the empty gui to an application with gui in order
> to test it. When I access the application the wms is displayed fine. But
> because the wms contains a lot of layers, most of which I don't want to use
> in the application, I would like to disable them in the wms application
> settings.
> That's where my problem occurs: When I make changes to the wms application
> settings and try to save them using the "save settings" button, all my
> changes disappear and are not saved. When I make changes to other wms
> services, saving the settings works just fine.
> I checked my installtion using the mapbender_setup.php but everything seems
> fine. The only error message I see is: "extension_dir		no extension_dir
> set!" but I don't think this has anything to do with my problem.
> Can anybody help me out here?
> Thanks, Lukas
> View this message in context: http://osgeo-org.1560.x6.nabble.com/MB-2-7-x-Can-t-save-wms-application-settings-tp5244512.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Von-Kuhl-Straße 49
56070 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
