[Mapbender-users] MB 2.7.x: Can't save wms application settings
Armin Retterath
armin.retterath at lvermgeo.rlp.de
Mon Jan 11 04:21:46 PST 2016
hi lukas,
no - only when you make your connections via a special proxy. if you
have a standard internet connection (maybe outside a dmz) you don't have
to set a proxy.
proxy settings without proxy:
define("CONNECTION_PROXY", "");
define("CONNECTION_PORT", "");
this it not really nice but you have to set the proxy to empty strings,
and there has to be installed the php5-curl library.
which operating system do you use?
armin
On 11.01.2016 13:05, lukas.bollack wrote:
> Hi Armin
> Thanks a lot, this was very helpful. I edited my php-ini to
> max_input_vars=6000 and now I can save the wms-settings :)
> As to setting curl as the connection method, I read the corresponding part
> of the mapbender installation guide but I'm not 100% sure what I'm supposed
> to do. I understand I have to edit my mapbender.conf-file.
> I think I have to change this:
> #define("CONNECTION", "curl");
> define("CONNECTION", "http");
> #define("CONNECTION", "socket");
> to this:
> #define("CONNECTION", "http");
> but then there's this part:
> define("CONNECTION_PROXY", "<ip>");
> define("CONNECTION_PORT", "<port>");
> define("CONNECTION_USER", "<user>");
> define("CONNECTION_PASSWORD", "<password>");
> Do I have to make changes here as well?
> Thanks
> Lukas
> View this message in context: http://osgeo-org.1560.x6.nabble.com/MB-2-7-x-Can-t-save-wms-application-settings-tp5244512p5244532.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Von-Kuhl-Straße 49
56070 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users
