[Mapbender-users] Load WFS in Mapbender3
Armin Retterath armin.retterath at vermkv.rlp.de
Mon Jun 13 22:44:22 PDT 2016
hello simone,
you may alternatively install parallel mapbender2 for the digitize via wfs-t and use mapbender3 for the presentation frontend ?
regards
armin
> Astrid Emde <astrid.emde at wheregroup.com> hat am 13. Juni 2016 um 16:03 geschrieben:
> Hello Simone,
> you can visualize data from GeoServer via WMS.
> If you want to add a search or digitizer to your application you can
> can't use WFS yet.
> Search and digitizer use SQL and access the data directly from the
> database.
> Read more at
> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/search_router.html
> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/digitizer.html
> We are discussing support for WFS in the team. But there is no concreate
> planning yet.
> Astrid
> Am 2016-06-13 15:42, schrieb Simone Micozzi:
> > Hi, all.
> > I intend to set up a web GIS application with MapBender3
> > backed by GeoServer as layers source.
> > I must confess I'm new of MapBender3,
> > but in the documentation I didn't find anything
> > about laoding WFS service in a MapBender3 application.
> > Can anyone kindly explain me if it is possible,
> > and, in that case, how to do that?
> > Thank you in advance,
> > Simone Micozzi
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> FOSSGIS Konferenz 2016 und AGIT 2016
> 4.-6. Juli 2016 & 6.-8. Juli 2016 in Salzburg
> http://fossgis-konferenz.de/2016/
> http://agit.at/
>   Astrid Emde
>   WhereGroup GmbH & Co.KG
>   Eifelstraße 7
>   53119 Bonn
>   Germany
>   Fon: +49(0)228 90 90 38 - 22
>   Fax: +49(0)228 90 90 38 - 11
>   www.wheregroup.com
>   Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
>   pgp-public key:
>   http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>   Signed and/or encrypted mail is highly appreciated
Armin Retterath
Zentrale Stelle GDI-RP
LVermGeo Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261 492-466
Telefax 0261 492-492
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
