[Mapbender-users] Load WFS in Mapbender3
Simone Micozzi micozzi.simone749 at tiscali.it
Tue Jun 14 02:18:59 PDT 2016
Hello you all.
No, luckily for this project I don't need transactional WFS.
So I think Mapbender3 will be enough.
Thank you both Amrin and Astrid,
Simone
Il giorno 14/giu/16, alle ore 08:09, Astrid Emde ha scritto:
> Hello,
> If you have a direct accees to your data via SQL in PostgreSQL I would
> not recommend to use Mapbender2 parallel.
> It is really fun to use the Mapbender3 digitizer and it is very
> powerfull.
> Though if you only can use WFS-T Mapbender2 is a good choice.
> Regards Astrid
> Am 14.06.2016 07:44, schrieb Armin Retterath:
>> hello simone,
>> you may alternatively install parallel mapbender2 for the digitize
>> via wfs-t and use mapbender3 for the presentation frontend ?
>> regards
>> armin
>>> Astrid Emde <astrid.emde at wheregroup.com> hat am 13. Juni 2016 um
>>> 16:03 geschrieben:
>>> Hello Simone,
>>> you can visualize data from GeoServer via WMS.
>>> If you want to add a search or digitizer to your application you can
>>> can't use WFS yet.
>>> Search and digitizer use SQL and access the data directly from the
>>> database.
>>> Read more at
>>> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/search_router.html
>>> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/digitizer.html
>>> We are discussing support for WFS in the team. But there is no
>>> concreate
>>> planning yet.
>>> Astrid
>>> Am 2016-06-13 15:42, schrieb Simone Micozzi:
>>>> Hi, all.
>>>> I intend to set up a web GIS application with MapBender3
>>>> backed by GeoServer as layers source.
>>>> I must confess I'm new of MapBender3,
>>>> but in the documentation I didn't find anything
>>>> about laoding WFS service in a MapBender3 application.
>>>> Can anyone kindly explain me if it is possible,
>>>> and, in that case, how to do that?
>>>> Thank you in advance,
>>>> Simone Micozzi
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Mit freundlichen Grüßen
>>> Astrid Emde
>>> GIS-Consultant
>>> FOSSGIS Konferenz 2016 und AGIT 2016
>>> 4.-6. Juli 2016 & 6.-8. Juli 2016 in Salzburg
>>> http://fossgis-konferenz.de/2016/
>>> http://agit.at/
>>>  Astrid Emde
>>>  WhereGroup GmbH & Co.KG
>>>  Eifelstraße 7
>>>  53119 Bonn
>>>  Germany
>>>  Fon: +49(0)228 90 90 38 - 22
>>>  Fax: +49(0)228 90 90 38 - 11
>>>  www.wheregroup.com
>>>  Folgen Sie der WhereGroup auf twitter:
>>> http://twitter.com/WhereGroup_com
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Olaf Knopp, Peter Stamm
>>>  pgp-public key:
>>>  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>>>  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>>>  Signed and/or encrypted mail is highly appreciated
>> Armin Retterath
>> Zentrale Stelle GDI-RP
>> LVermGeo Rheinland-Pfalz
>> Ferdinand-Sauerbruch-Straße 15
>> 56073 Koblenz
>> Telefon 0261 492-466
>> Telefax 0261 492-492
>> armin.retterath at vermkv.rlp.de
>> http://www.geoportal.rlp.de
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
> Astrid Emde
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 19
> www.wheregroup.com
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Komplementärin:
> vertreten durch:
> pgp-public key:
More information about the Mapbender_users mailing list
