[Mapbender-users] No more login possible
Uwe Seher uwe.seher at gmail.com
Wed Jun 15 06:36:34 PDT 2016
Hello again!
While experimenting with css in the Demo-Template and trying to change the
logo suddenly the following happend:
When trying to log in the normal screen and login form appears. After
typing login and password the screen turns white. The apache error log
shows the following error:
[Wed Jun 15 15:09:25.248415 2016] [php5:error] [pid 5229] [client
xxx.xxx.xxx.xxx:52144] PHP Fatal error:  Undefined class constant
'MAX_USERNAME_LENGTH' in
/srv/www/htdocs/mapbender3-3.0.5.3/vendor/symfony/symfony/src/Symfony/Component/Security/Http/Firewall/UsernamePasswordFormAuthenticationListener.php
on line 87, referer: <address>/mb3/user/login
In app/logs/prod.log appears the following (but this must not have
something to do with the above error):
[2016-06-15 13:09:16] request.ERROR: Uncaught PHP Exception
Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route
found for "GET /upload/ibk/ibk_logo_print_kurz.jpg"" at
/srv/www/htdocs/mapbender3-3.0.5.3/app/cache/prod/classes.php line 1887
{"exception":"[object]
(Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code: 0):
No route found for \"GET /upload/ibk/ibk_logo_print_kurz.jpg\" at
/srv/www/htdocs/mapbender3-3.0.5.3/app/cache/prod/classes.php:1887,
Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code:
0):  at
/srv/www/htdocs/mapbender3-3.0.5.3/app/cache/prod/appProdUrlMatcher.php:1063)"}
No user can log in, changing the password does not matter but seems to work.
What had happened here and where can i look to repair this?
Thank you in advance for your help and regards
Uwe
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160615/8f24f232/attachment.html>
More information about the Mapbender_users mailing list
