[Mapbender-users] MB 2.7.x: Can't save wms application settings
Armin Retterath armin.retterath at vermkv.rlp.de
Tue Mar 1 03:39:55 PST 2016
hi lukas,
a simple solution to solve the one problem with
http://wms.zh.ch/OrthoZHWMS?REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=wms is
to store the capabilities into the mapbender/http/geoportal/ folder and register
it local withfollowing path:
file:///var/www/naturschutz.com/mapbender/http/geoportal/{nameofcaps}.xml
mapbender can register local files ! ;-)
you can also update the service with a local path
to test the secured services we have to activate the owsproxy ...
regards
armin
> Armin Retterath <armin.retterath at vermkv.rlp.de> hat am 1. März 2016 um 12:29
> geschrieben:
> no - it's the servers problem - i try to test them ;-)
> is one of the services authenticated ?
> > Armin Retterath <armin.retterath at vermkv.rlp.de> hat am 1. März 2016 um 12:28
> > geschrieben:
> > please deactivate Deny from all with a # in your proxy.conf:
> > ProxyRequests Off
> > <Proxy *>
> > AddDefaultCharset off
> > Order deny,allow
> > #Deny from all
> > Allow from all
> > </Proxy>
> > > 12:19
> > > geschrieben:
> > > hi lukas,
> > > i registered an external service in your application, and it works as
> > > expected.
> > > in our geoportal the url
> > > http://wms.zh.ch/OrthoZHWMS?SERVICE=WMS&Request=GetCapabilities&VERSION=1.1.1
> > > also make trouble -
> > > i check it local after lunch ;-)
> > > regards
> > > armin
> > > > "lukas.bollack" <lukas.bollack at naturnetz.ch> hat am 1. März 2016 um
> > > > 11:57
> > > > geschrieben:
> > > > hi Armin
> > > > I'm in a bit of a panic here. Those wms used to work, I uploaded them
> > > > into
> > > > my mapbender database and it was fine. Why is it not working anymore?
> > > > In my mapbender conf there is this line:
> > > > define("CONNECTION_USERAGENT", "Mapbender");
> > > > I worry that I might have messed up my wms table in the mapbender
> > > > databse.
> > > > I
> > > > edited it manually (adding values in the username, password and
> > > > connection
> > > > method field of a wms service).
> > > > mod-rewrite is enabled.
> > > > /etc/apache2/sites-available/ and /etc/apache2/sites-enabled/ look like
> > > > this:
> > > > <http://osgeo-org.1560.x6.nabble.com/file/n5253577/folders.png>
> > > > View this message in context:
> > > > http://osgeo-org.1560.x6.nabble.com/MB-2-7-x-Can-t-save-wms-application-settings-tp5244512p5253577.html
> > > > Sent from the mapbender-users mailing list archive at Nabble.com.
> > > > _______________________________________________
> > > > Mapbender_users mailing list
> > > > Mapbender_users at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > > Armin Retterath
> > > Zentrale Stelle GDI-RP
> > > LVermGeo Rheinland-Pfalz
> > > Ferdinand-Sauerbruch-Straße 15
> > > 56073 Koblenz
> > > Telefon 0261 492-466
> > > Telefax 0261 492-492
> > > http://www.geoportal.rlp.de
> > Armin Retterath
> > 56073 Koblenz
> Armin Retterath
> 56073 Koblenz
Armin Retterath
56073 Koblenz
More information about the Mapbender_users mailing list
