[Mapbender-users] Connection error with geometry server, internal error 500
Astrid Emde astrid.emde at wheregroup.com
Sun May 1 23:27:59 PDT 2016
Hi Zhandos,
please check the real name of your Database in PostgreSQL. Is it named
seach_db as you wrote in parameter.yml (/database2_name:     search_db)/?
Are you allowed to access the database?
Clear the cache
Call Mapbender with app_dev.php to get the errors. Something like
http://localhost/mapbender3/app_dev.php
The rest looks fine.
Best regards
Astrid
Am 30.04.2016 09:09, schrieb zh.kerimkulov at gharysh.kz:
> Hello Mapbender Users!!!
> I tried to use Digitizer element, but faced connection error with
> geometry server.
> Step by step:
> 1/ I changed config.yml file:
> /doctrine:/
> /    dbal:/
> /        default_connection: default/
> /        connections:/
> /            default:/
> /                driver:   %database_driver%/
> /                host:     %database_host%/
> /                port:     %database_port%/
> /                dbname:   %database_name%/
> /                path:     %database_path%/
> /                user:     %database_user%/
> /                password: %database_password%/
> /                charset:  UTF8/
> /                logging: %kernel.debug%/
> /                profiling: %kernel.debug%/
> /            search_db:/
> /                driver:   %database2_driver%/
> /                host:     %database2_host%/
> /                port:     %database2_port%/
> /                dbname:   %database2_name%/
> /                path:     %database2_path%/
> /                user:     %database2_user%/
> /                password: %database2_password%/
> /                charset:  UTF8/
> 2/ and parameters.yml file.
> /parameters:/
> /    # database-connection "default"/
> /    database_driver:   pdo_pgsql/
> /    database_host:     localhost/
> /    database_port:     5432/
> /    database_name:     mapbender3/
> /    database_path:     ~/
> /    database_user:     postgres/
> /    database_password: postgres/
> /    # database-connection "search_db"/
> /    database2_driver:   pdo_pgsql/
> /    database2_host:     localhost/
> /    database2_port:     5432/
> /    database2_name:     search_db/
> /    database2_path:     ~/
> /    database2_user:     postgres/
> /    database2_password: postgres/
> 3/ then I tried to create DB by console utility like this: app/console
> doctrine:database:create
> But this utility create only default DB, /search_db/did not created by
> script. I create it manually and added extension Postgis. After that I
> added tables with SQL query for tables table public.poi,
> public.polygons, public.lines, then I added Digitizer element to the
> side panel of application and put YAML-Definition to the textarea
> schemes but it did not solve the problem, I still have  "Connection
> error with geometry server, internal error 500".
> Thank you,
> Zhandos
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
 pgp-public key:
 http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160502/839921a4/attachment.html>
More information about the Mapbender_users mailing list
