[Mapbender-users] Connection error with geometry server, internal error 500
Patrick Meis
Meis at stadt-muenster.de
Mon May 2 02:15:09 PDT 2016
Hello everybody,
as I'm still having trouble to get a connection to my search_db too, I just tried to start Mapbender 3 with app_dev, as
Astrid suggested, to read the errors.
Now I discovered that with app_dev my connection sems to be working, and I finally got results in my search router.
Whereas when I am starting Mapbender normally (without app_dev) the search router keeps on saying "no results"
and the prod.log says:
request.CRITICAL: Uncaught PHP Exception Symfony\Component\DepenencyInjection\Exception\ServiceNotFoundException:
"You have requested a non-existent service "doctrine.dbal.geo_osm_connection". Did you mean this: "doctrine.dbal.default.connection"?
at /var/www/mapbender3/app/bootstrap.php.cache line 2027
My database is not on localhost.
The configuration is as:
parameters:
# database-connection "default"
database_driver: pdo_sqlite
database_host: ~
database_port: ~
database_name: ~
database_path: %kernel.root_dir%/db/demo.sqlite
database_user: ~
database_password: ~
# database-connection "geo_osm"
database2_driver: pdo_pgsql
database2_host: 172.30.212.142
database2_port: 5432
database2_name: geo_osm
database2_path: ~
database2_user: geo_osm
database2_password: ********
Now the question is:
what is different when I try the search router request with app_dev???
Greets
Patrick
Am 02.05.2016 09:09, schrieb astrid.emde at wheregroup.com:
Hi Zhandos,
please check the real name of your Database in PostgreSQL. Is it named seach_db as you wrote in parameter.yml (database2_name: search_db)?
Are you allowed to access the database?
Clear the cache
Call Mapbender with app_dev.php to get the errors. Something like http://localhost/mapbender3/app_dev.php
The rest looks fine.
Best regards
Astrid
Am 30.04.2016 09:09, schrieb zh.kerimkulov at gharysh.kz:
Hello Mapbender Users!!!
I tried to use Digitizer element, but faced connection error with geometry server.
Step by step:
1/ I changed config.yml file:
doctrine:
dbal:
default_connection: default
connections:
default:
driver: %database_driver%
host: %database_host%
port: %database_port%
dbname: %database_name%
path: %database_path%
user: %database_user%
password: %database_password%
charset: UTF8
logging: %kernel.debug%
profiling: %kernel.debug%
search_db:
driver: %database2_driver%
host: %database2_host%
port: %database2_port%
dbname: %database2_name%
path: %database2_path%
user: %database2_user%
password: %database2_password%
charset: UTF8
2/ and parameters.yml file.
parameters:
database_driver: pdo_pgsql
database_host: localhost
database_port: 5432
database_name: mapbender3
database_path: ~
database_user: postgres
database_password: postgres
# database-connection "search_db"
database2_host: localhost
database2_path: ~
database2_user: postgres
database2_password: postgres
3/ then I tried to create DB by console utility like this: app/console doctrine:database:create
But this utility create only default DB, search_db did not created by script. I create it manually and added extension Postgis. After that I added tables with SQL query for tables table public.poi, public.polygons, public.lines, then I added Digitizer element to the side panel of application and put YAML-Definition to the textarea schemes but it did not solve the problem, I still have "Connection error with geometry server, internal error 500".
Thank you,
Zhandos
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160502/5dc608cf/attachment-0001.html>
More information about the Mapbender_users
