[Mapbender-users] Connection error with geometry server, internal error 500
Jens Schaefermeyer - WhereGroup jens.schaefermeyer at wheregroup.com
Mon May 2 02:46:28 PDT 2016
Hi Patrick,
I assume, that you didn't clear your cache after you edited your
parameters.yml and config.yml. When you use the app_dev.php you don't
have to clear the cache, in order to see your changes.
With kind regards,
Jens
Am 02.05.2016 um 11:15 schrieb Patrick Meis:
> Hello everybody,
> as I’m still having trouble to get a connection to my search_db too, I
> just tried to start Mapbender 3 with app_dev, as
> Astrid suggested, to read the errors.
> Now I discovered that with app_dev my connection sems to be working,
> and I finally got results in my search router.
> Whereas when I am starting Mapbender normally (without app_dev) the
> search router keeps on saying “no results”
> and the prod.log says:
> request.CRITICAL: Uncaught PHP Exception
> Symfony\Component\DepenencyInjection\Exception\ServiceNotFoundException:
> “You have requested a non-existent service
> “doctrine.dbal.geo_osm_connection”. Did you mean this:
> “doctrine.dbal.default.connection”?
> at /var/www/mapbender3/app/bootstrap.php.cache line 2027
> My database is not on localhost.
> The configuration is as:
> parameters:
>     # database-connection "default"
>     database_driver:  pdo_sqlite
>     database_host:     ~
>     database_port:     ~
>     database_name:     ~
>     database_path: %kernel.root_dir%/db/demo.sqlite
>     database_user:     ~
>     database_password: ~
>     # database-connection "geo_osm"
>     database2_driver: pdo_pgsql
>     database2_host: 172.30.212.142
>     database2_port: 5432
>     database2_name: geo_osm
>     database2_path: ~
>     database2_user: geo_osm
>     database2_password: ********
> Now the question is:
> what is different when I try the search router request with app_dev???
> Greets
> Patrick
> Am 02.05.2016 09:09, schrieb astrid.emde at wheregroup.com:
> Hi Zhandos,
> please check the real name of your Database in PostgreSQL. Is it named
> seach_db as you wrote in parameter.yml (database2_name:     search_db)?
> Are you allowed to access the database?
> Clear the cache
> Call Mapbender with app_dev.php to get the errors. Something like
> http://localhost/mapbender3/app_dev.php
> The rest looks fine.
> Best regards
> Astrid
> Am 30.04.2016 09:09, schrieb zh.kerimkulov at gharysh.kz:
> Hello Mapbender Users!!!
> I tried to use Digitizer element, but faced connection error with
> geometry server.
> Step by step:
> 1/ I changed config.yml file:
> doctrine:
>     dbal:
> default_connection: default
>         connections:
>             default:
> driver:   %database_driver%
> host:     %database_host%
> port:     %database_port%
> dbname:   %database_name%
>                 path:  %database_path%
> user:     %database_user%
> password: %database_password%
> charset:  UTF8
>                 logging: %kernel.debug%
> profiling: %kernel.debug%
>             search_db:
>  driver:   %database2_driver%
> host:     %database2_host%
> port:     %database2_port%
> dbname:   %database2_name%
> path:     %database2_path%
> user:     %database2_user%
> password: %database2_password%
> charset:  UTF8
> 2/ and parameters.yml file.
> parameters:
>     database_driver: pdo_pgsql
>     database_host: localhost
>     database_port: 5432
>     database_name: mapbender3
>     database_path:     ~
>     database_user: postgres
>     database_password: postgres
>     # database-connection "search_db"
>     database2_host: localhost
>     database2_path: ~
>     database2_user: postgres
>     database2_password: postgres
> 3/ then I tried to create DB by console utility like this: app/console
> doctrine:database:create
> But this utility create only default DB, search_db did not created by
> script. I create it manually and added extension Postgis. After that I
> added tables with SQL query for tables table public.poi,
> public.polygons, public.lines, then I added Digitizer element to the
> side panel of application and put YAML-Definition to the textarea
> schemes but it did not solve the problem, I still have  "Connection
> error with geometry server, internal error 500".
> Thank you,
> Zhandos
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Jens Schaefermeyer
Projektleiter
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 31
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160502/2ac5d79a/attachment.html>
More information about the Mapbender_users mailing list
