[Mapbender-users] Digitizer
Charlotte Toma charlotte.toma at wheregroup.com
Thu Nov 24 00:32:28 PST 2016
Hello,
you can style the apperance of your digitizer features. Here are two
examples for points and polygons:
    displayPermanent: false
    styles:
        default:                      # style without the selection of a
geometry
            strokeWidth: 2
            strokeColor: '#0e6a9e'
            fillColor: '#1289CD'
            fillOpacity: 1
            fillWidth: 2
            pointRadius: 10
        select:                       # style when a geometry is selected
            strokeWidth: 3
            fillOpacity: 0.7
            pointRadius: 10
or for polygons:
  styles:
    default:
      strokeWidth: 2
      fillOpacity: 1
      fillWidth: 2
      pointRadius: 0.1
    select:
      strokeWidth: 3
      fillOpacity: 0.7
      pointRadius: 10
with this parameter you can put a color to the polygons in the map while
the digitizer is active. I would also make the wms with diffrent colors
(via classes) of an attribute in the digitizer-form.
Mit freundlichen Grüßen
Charlotte Toma
GIS-Consultant
Where2B Konferenz 2016
15. Dezember 2016 in Bonn
www.where2b-conference.com
 Charlotte Toma
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 24
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 24.11.2016 um 09:13 schrieb Patrick Meis:
> Hello fellow users,
> I am currently experimenting with the digitizer module, wanting to
> provide our firefighters with
> a means to create polygons (with two attached attributes).
> Is it possible to directly put a color to the polygons (defined by one
> of the attributes)?
> Or, if not, to toggle the whole toolset “digitizer” and the display of
> the polygons off?
> I would then make a WMS out of the layer and style that accordingly.
> But with the digitizer constantly in “on-mode”, the polygons would
> overlap.
> Connecting the digitizer to a “Button”-feature doesn’t seem to work too.
> Am I missing something obvious?
> Greets and thanks for advice
> Patrick
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161124/fdd95127/attachment.html>
More information about the Mapbender_users mailing list
