[Mapbender-users] php issues trying to install mapbender3 on Debian/testing with php7
Frederik Haefker (WhereGroup)
frederik.haefker at wheregroup.com
Tue Oct 11 08:58:31 PDT 2016
Hi Moritz,
did you rename your "parameter.yml.dist" in following folder
"app/config/" by removing the ".dist"?
Best Regards
Frederik
Am 11.10.2016 um 17:34 schrieb Moritz Lennert:
> Hello there,
> I'm new to Mapbender and am having quite some issues just trying to
> install it. Any help would be appreciated.
> Below a summary of my situation and of what I've done.
> Thanks !
> Moritz
> OS: Debian testing
> Apache Version: 2.4.23
> PHP Debian version: 1:7.0+45
> I "apt-get removed" any remaining installed php5 packages (php5 is no
> longer supported in Debian testing)
> sudo apt-get install apache2 libapache2-mod-php php php-pgsql php-gd
> php-curl php-cli php-xml php-sqlite3 sqlite3 php-apcu php-intl openssl
> php-zip php-mbstring php-bz2
> sudo a2enmod rewrite
> cd /var/www
> sudo tar xvzf ~/SRC/mapbender3-3.0.5.3.tar.gz
> sudo mv mapbender3-3.0.5.3/ mapbender3
> sudo vi mapbender3.conf
> Alias /mapbender3 /var/www/mapbender3/web/
> <Directory /var/www/mapbender3/web/>
> Options MultiViews FollowSymLinks
> DirectoryIndex app.php
> Require all granted
> RewriteEngine On
> RewriteBase /mapbender3/
> RewriteCond %{REQUEST_FILENAME} !-f
> RewriteRule ^(.*)$ app.php [QSA,L]
> </Directory>
> sudo a2ensite mapbender3.conf
> sudo service apache2 reload
> When I now point my browser to
> http://localhost/mapbender3/
> I get a page with this:
> register(true); */ require_once __DIR__.'/../app/AppKernel.php';
> //require_once __DIR__.'/../app/AppCache.php'; $kernel = new
> AppKernel('prod', false); $kernel->loadClassCache(); //$kernel = new
> AppCache($kernel); $request = Request::createFromGlobals(); $response
> = $kernel->handle($request); $response->send();
> $kernel->terminate($request, $response);
> When I point it to
> http://localhost/mapbender3/config.php
> I get to the config page, but with apparently a series of PHP issues
> (see attached screenshot)
> After having seen an error about date.timezone on
> http://doc.mapbender3.org/en/book/installation/installation_ubuntu.html:
> sudo vi /etc/php/7.0/cli/php.ini
> sudo vi /etc/php/7.0/apache2/php.ini
> date.timezone = Europe/Brussels
> sudo service apache2 restart
> => same result
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Ps.: bitte beachten Sie die Möglichkeit den Schriftverkehr mit meinem public-PGP-key zu schützen:
http://pool.sks-keyservers.net/pks/lookup?op=vindex&search=frederik+haefker
INTERGEO 2016
11.- 13. Oktober 2016 in Hamburg
Treffen Sie die WhereGroup in Halle A4, Stand B4.028
www.intergeo.de
Frederik Haefker
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 0
Fax: +49 (0)228 / 90 90 38 - 11
PGP Key: http://pool.sks-keyservers.net/pks/lookup?op=vindex&search=frederik+haefker
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161011/3da280c9/attachment.html>
More information about the Mapbender_users
