[Mapbender-users] php issues trying to install mapbender3 on Debian/testing with php7
Moritz Lennert mlennert at club.worldonline.be
Wed Oct 12 06:39:27 PDT 2016
Hi Frederik,
Thank you for the quick response !
On 11/10/16 17:58, Frederik Haefker (WhereGroup) wrote:
> Hi Moritz,
> did you rename your "parameter.yml.dist" in following folder
> "app/config/" by removing the ".dist"?
I've just tried this, but no changes.
This step is only described in [1] which is announced as "Installation
in the Symfony built-in webserver". I didn't think I had to go through
there.
Looking at this I tried to run and reach the Symfony server with:
sudo app/console server:run
which gives me
"Server running on http://localhost:8000"
But when I point my browser to that address, I get:
"Firefox can't establish a connection to the server at localhost:8000."
I've tried stopping the apache2 service in order to avoid any possible
conflicts, but to no avail.
I've also gone a bit further in the Ubuntu/Debian installation guide [2]
and changed the ownership of all files to www-data with:
sudo chmod -R ugo+r /var/www/mapbender3
sudo chown -R www-data:www-data /var/www/mapbender3
sudo chmod -R ug+w /var/www/mapbender3/web/uploads
No changes either. I still get the same unreadable web page...
Moritz
[1] http://doc.mapbender3.org/en/book/installation/installation_symfony.html
[2] http://doc.mapbender3.org/en/book/installation/installation_ubuntu.html
> Best Regards
> Frederik
> Am 11.10.2016 um 17:34 schrieb Moritz Lennert:
>> Hello there,
>> I'm new to Mapbender and am having quite some issues just trying to
>> install it. Any help would be appreciated.
>> Below a summary of my situation and of what I've done.
>> Thanks !
>> Moritz
>> OS: Debian testing
>> Apache Version: 2.4.23
>> PHP Debian version: 1:7.0+45
>> I "apt-get removed" any remaining installed php5 packages (php5 is no
>> longer supported in Debian testing)
>> sudo apt-get install apache2 libapache2-mod-php php php-pgsql php-gd
>> php-curl php-cli php-xml php-sqlite3 sqlite3 php-apcu php-intl openssl
>> php-zip php-mbstring php-bz2
>> sudo a2enmod rewrite
>> cd /var/www
>> sudo tar xvzf ~/SRC/mapbender3-3.0.5.3.tar.gz
>> sudo mv mapbender3-3.0.5.3/ mapbender3
>> sudo vi mapbender3.conf
>> Alias /mapbender3 /var/www/mapbender3/web/
>> <Directory /var/www/mapbender3/web/>
>>  Options MultiViews FollowSymLinks
>>  DirectoryIndex app.php
>>  Require all granted
>>  RewriteEngine On
>>  RewriteBase /mapbender3/
>>  RewriteCond %{REQUEST_FILENAME} !-f
>>  RewriteRule ^(.*)$ app.php [QSA,L]
>> </Directory>
>> sudo a2ensite mapbender3.conf
>> sudo service apache2 reload
>> When I now point my browser to
>> http://localhost/mapbender3/
>> I get a page with this:
>> register(true); */ require_once __DIR__.'/../app/AppKernel.php';
>> //require_once __DIR__.'/../app/AppCache.php'; $kernel = new
>> AppKernel('prod', false); $kernel->loadClassCache(); //$kernel = new
>> AppCache($kernel); $request = Request::createFromGlobals(); $response
>> = $kernel->handle($request); $response->send();
>> $kernel->terminate($request, $response);
>> When I point it to
>> http://localhost/mapbender3/config.php
>> I get to the config page, but with apparently a series of PHP issues
>> (see attached screenshot)
>> After having seen an error about date.timezone on
>> http://doc.mapbender3.org/en/book/installation/installation_ubuntu.html:
>> sudo vi /etc/php/7.0/cli/php.ini
>> sudo vi /etc/php/7.0/apache2/php.ini
>> date.timezone = Europe/Brussels
>> sudo service apache2 restart
>> => same result
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Ps.: bitte beachten Sie die Möglichkeit den Schriftverkehr mit meinem public-PGP-key zu schützen:
> http://pool.sks-keyservers.net/pks/lookup?op=vindex&search=frederik+haefker
> INTERGEO 2016
> 11.- 13. Oktober 2016 in Hamburg
> Treffen Sie die WhereGroup in Halle A4, Stand B4.028
> www.intergeo.de
> Frederik Haefker
> WhereGroup GmbH & Co. KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 0
> Fax: +49 (0)228 / 90 90 38 - 11
> PGP Key: http://pool.sks-keyservers.net/pks/lookup?op=vindex&search=frederik+haefker
> frederik.haefker at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
