[Mapbender-users] php issues trying to install mapbender3 on Debian/testing with php7
Moritz Lennert
mlennert at club.worldonline.be
Thu Oct 13 02:33:37 PDT 2016
Sorry, my bad: I forgot to run "sudo a2enmod php7.0".
(maybe a note about this in the doc might be good)
Now http://localhost/mapbender3 gives me Mapbender ! ;-)
Sorry for the noise,
Moritz
On 12/10/16 15:51, Moritz Lennert wrote:
> Some more info:
> Using Chromium (instead of Firefox), I get the entire php code displayed
> in the browser, be it for
> - http://localhost/mapbender3 (i.e. web/app.php) or
> - http://localhost/mapbender3/config.php (i.e. web/config.php)
> And here are all the php related packages that are installed on my machine:
> dpkg -l "*php*" | grep ii | awk '{print $1, $2, $3}'
> ii libapache2-mod-php 1:7.0+45
> ii libapache2-mod-php7.0 7.0.11-1
> ii php 1:7.0+45
> ii php-apcu 5.1.5+4.0.11-1
> ii php-apcu-bc 1.0.3-2
> ii php-bz2 1:7.0+45
> ii php-cli 1:7.0+45
> ii php-common 1:44
> ii php-curl 1:7.0+45
> ii php-gd 1:7.0+45
> ii php-intl 1:7.0+45
> ii php-mbstring 1:7.0+45
> ii php-mdb2 2.5.0b5-2
> ii php-mdb2-driver-pgsql 1.5.0b4-2
> ii php-pear 1:1.10.1+submodules+notgz-8
> ii php-pgsql 1:7.0+45
> ii php-sqlite3 1:7.0+45
> ii php-xml 1:7.0+45
> ii php-zip 1:7.0+45
> ii php7.0 7.0.11-1
> ii php7.0-bz2 7.0.11-1
> ii php7.0-cli 7.0.11-1
> ii php7.0-common 7.0.11-1
> ii php7.0-curl 7.0.11-1
> ii php7.0-gd 7.0.11-1
> ii php7.0-intl 7.0.11-1
> ii php7.0-json 7.0.11-1
> ii php7.0-mbstring 7.0.11-1
> ii php7.0-opcache 7.0.11-1
> ii php7.0-pgsql 7.0.11-1
> ii php7.0-readline 7.0.11-1
> ii php7.0-sqlite3 7.0.11-1
> ii php7.0-xml 7.0.11-1
> ii php7.0-zip 7.0.11-1
> Moritz
> On 12/10/16 15:39, Moritz Lennert wrote:
>> Hi Frederik,
>> Thank you for the quick response !
>> On 11/10/16 17:58, Frederik Haefker (WhereGroup) wrote:
>>> Hi Moritz,
>>> did you rename your "parameter.yml.dist" in following folder
>>> "app/config/" by removing the ".dist"?
>> I've just tried this, but no changes.
>> This step is only described in [1] which is announced as "Installation
>> in the Symfony built-in webserver". I didn't think I had to go through
>> there.
>> Looking at this I tried to run and reach the Symfony server with:
>> sudo app/console server:run
>> which gives me
>> "Server running on http://localhost:8000"
>> But when I point my browser to that address, I get:
>> "Firefox can't establish a connection to the server at localhost:8000."
>> I've tried stopping the apache2 service in order to avoid any possible
>> conflicts, but to no avail.
>> I've also gone a bit further in the Ubuntu/Debian installation guide [2]
>> and changed the ownership of all files to www-data with:
>> sudo chmod -R ugo+r /var/www/mapbender3
>> sudo chown -R www-data:www-data /var/www/mapbender3
>> sudo chmod -R ug+w /var/www/mapbender3/web/uploads
>> No changes either. I still get the same unreadable web page...
>> Moritz
>> [1]
>> http://doc.mapbender3.org/en/book/installation/installation_symfony.html
>> [2]
>> http://doc.mapbender3.org/en/book/installation/installation_ubuntu.html
>>> Best Regards
>>> Frederik
>>> Am 11.10.2016 um 17:34 schrieb Moritz Lennert:
>>>> Hello there,
>>>> I'm new to Mapbender and am having quite some issues just trying to
>>>> install it. Any help would be appreciated.
>>>> Below a summary of my situation and of what I've done.
>>>> Thanks !
>>>> Moritz
>>>> OS: Debian testing
>>>> Apache Version: 2.4.23
>>>> PHP Debian version: 1:7.0+45
>>>> I "apt-get removed" any remaining installed php5 packages (php5 is no
>>>> longer supported in Debian testing)
>>>> sudo apt-get install apache2 libapache2-mod-php php php-pgsql php-gd
>>>> php-curl php-cli php-xml php-sqlite3 sqlite3 php-apcu php-intl openssl
>>>> php-zip php-mbstring php-bz2
>>>> sudo a2enmod rewrite
>>>> cd /var/www
>>>> sudo tar xvzf ~/SRC/mapbender3-3.0.5.3.tar.gz
>>>> sudo mv mapbender3-3.0.5.3/ mapbender3
>>>> sudo vi mapbender3.conf
>>>> Alias /mapbender3 /var/www/mapbender3/web/
>>>> <Directory /var/www/mapbender3/web/>
>>>> Options MultiViews FollowSymLinks
>>>> DirectoryIndex app.php
>>>> Require all granted
>>>> RewriteEngine On
>>>> RewriteBase /mapbender3/
>>>> RewriteCond %{REQUEST_FILENAME} !-f
>>>> RewriteRule ^(.*)$ app.php [QSA,L]
>>>> </Directory>
>>>> sudo a2ensite mapbender3.conf
>>>> sudo service apache2 reload
>>>> When I now point my browser to
>>>> I get a page with this:
>>>> register(true); */ require_once __DIR__.'/../app/AppKernel.php';
>>>> //require_once __DIR__.'/../app/AppCache.php'; $kernel = new
>>>> AppKernel('prod', false); $kernel->loadClassCache(); //$kernel = new
>>>> AppCache($kernel); $request = Request::createFromGlobals(); $response
>>>> = $kernel->handle($request); $response->send();
>>>> $kernel->terminate($request, $response);
>>>> When I point it to
>>>> I get to the config page, but with apparently a series of PHP issues
>>>> (see attached screenshot)
>>>> After having seen an error about date.timezone on
>>>> http://doc.mapbender3.org/en/book/installation/installation_ubuntu.html:
>>>> sudo vi /etc/php/7.0/cli/php.ini
>>>> sudo vi /etc/php/7.0/apache2/php.ini
>>>> date.timezone = Europe/Brussels
>>>> sudo service apache2 restart
>>>> => same result
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Ps.: bitte beachten Sie die Möglichkeit den Schriftverkehr mit meinem
>>> public-PGP-key zu schützen:
>>> http://pool.sks-keyservers.net/pks/lookup?op=vindex&search=frederik+haefker
>>> INTERGEO 2016
>>> 11.- 13. Oktober 2016 in Hamburg
>>> Treffen Sie die WhereGroup in Halle A4, Stand B4.028
>>> www.intergeo.de
>>> Frederik Haefker
>>> WhereGroup GmbH & Co. KG
>>> Eifelstraße 7
>>> 53119 Bonn
>>> Germany
>>> Fon: +49 (0)228 / 90 90 38 - 0
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> PGP Key:
>>> frederik.haefker at wheregroup.com
>>> www.wheregroup.com
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Olaf Knopp, Peter Stamm
More information about the Mapbender_users
