[Mapbender-users] 'Feature Info' works for certain WMS only in the "WMS loader", but not when added from 'source'
Astrid Emde astrid.emde at wheregroup.com
Thu Sep 15 03:44:30 PDT 2016
Hello Henning,
looks like it has to do with the featureInfo format.
You would like to get a featureInfo answer in text/html.
Please go to your application-Layerset->GeoServer WMS and check the WMS
infoformat. It should be set to text/html. Please save afterwards.
GeoServer offers many infoformats in the getCapabilities Document.
Mapbender chooses the first which is not always text/html.
Astrid
Am 2016-09-15 12:16, schrieb Henning Lorenz:
> Mapbender v.3.0.5.3; Geoserver 2.9.1
> Hello,
> - I have a WMS V.1.1.1 from Geoserver that I want to add to Mapbender 3
> - I can add the WMS without problems as a source
> - When I add layers from the WMS to a map, e.g. to one of the
> templates that come with Mapbender3, they show up correctly but:
>              * ‘Feature Info’ returns a ‘WMS server: no result’ for my
> layer
>              * ‘Feature Info’ works correctly on other WMS layers,
> like the Mapbender3 user map
> - When I add the very same WMS through the WMS loader, then ‘Feature
> Info’ works just fine.
> ———— this does not depend on the CRS, i.e. whether original or
> projected.
> - When I add this WMS to the same map twice, once as map layers from
> ‘sources’ and then again through ‘WMS loader’ and query the same
> feature  of the same layer in both WMSs with on click, i.e. at the
> same time, then the query on the ‘WMS loader’ layer returns a correct
> ‘Feature Info’ while the layer from ’sources’ returns ‘WMS server: no
> result’.
> Where is the difference between the ‘WMS loader’ and the ‘sources’?
> I’m grateful for any hint that helps me with troubleshooting.
> Thank you!
> Henning
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
INTERGEO 2016
11.- 13. Oktober 2016 in Hamburg
Treffen Sie die WhereGroup in Halle A4, Stand B4.028
www.intergeo.de
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
  pgp-public key:
  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
