[Mapbender-users] Installation issue Mapbender 3
Charlotte Toma charlotte.toma at wheregroup.com
Fri Aug 4 00:50:37 PDT 2017
Good morning,
the "non-existent parameter" database_host is from the database
definition in the parameters.yml (app/config). You propably defined a
false value in the database connection in the config.yml
parameters:
    # database-connection "default"
    database_driver:   pdo_pgsql
    database_host:     localhost
    database_port:     5432
    database_name:     mapbender3
    database_path:     ~
    database_user:     postgres
    database_password: postgres
Documentation is here: https://doc.mapbender3.org/en/book/database.html
Mit freundlichen Grüßen
Charlotte Toma
GIS-Consultant
FOSS Academy Sommerschule 2017
Aufbau von Geodateninfrastrukturen mit Open-Source-Software
11.-15. September 2017
www.foss-academy.com/sommerschule
 Charlotte Toma
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 24
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 03.08.2017 um 22:20 schrieb Nelson Lovestrom:
> Having an issue with getting mapbender 3 up and running.
> I have Apache24 64 bit. and PHP 5.6 64 bit.
> I've configured both of those correctly to talk to each other.
> I've went through the steps to install mapbender3 as found
> here. https://doc.mapbender3.org/en/book/installation/installation_windows.html
> When I get to this part
> c:
> cd mapbender3
> php.exe app/console doctrine:database:create
> php.exe app/console doctrine:schema:create
> php.exe app/console assets:install web
> php.exe app/console fom:user:resetroot
> php.exe app/console doctrine:fixtures:load --fixtures=./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Epsg/ --append
> php.exe app/console doctrine:fixtures:load --fixtures=./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Application/ --append
> the first php.exe line throws a fatal error with the message 'You have
> requested a non-existent parameter "database_host".
> How do I fix this and get Mapbender running?
> Nelson Lovestrom
> B.A., P.G. Dip.
> GIS Technician
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170804/2e526c82/attachment.html>
More information about the Mapbender_users mailing list
