[Mapbender-users] Installation issue Mapbender 3
Astrid Emde
astrid.emde at wheregroup.com
Tue Aug 8 02:29:08 PDT 2017
Hello Nelson,
you should not edit config.yml and refer hardcoded to the variables.
Make sure that parameters.yml is there and in use. There are some more
variables in parameters.yml that are nedded.
Copy parameters.yml.dist and create your parameters.yml file.
It is possible that you can ignore the message concerning date.timezone.
Your definition looks good.
Astrid
Am 2017-08-04 22:16, schrieb Nelson Lovestrom:
> So I made corrections within config.yml so now they are hardcoded as
> the same values as in parameter.yml.
> Now I get the Date.Time error when running doctrine:database:create.
> This is despite having that defined in php.ini
> code as written:
> [Date]
> ; Defines the default timezone used by the date functions
> ; http://php.net/date.timezone
> date.timezone = "America/Vancouver"
> On Fri, Aug 4, 2017 at 12:00 PM,
> <mapbender_users-request at lists.osgeo.org> wrote:
>> Send Mapbender_users mailing list submissions to
>> mapbender_users at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users [1]
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> mapbender_users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of Mapbender_users digest..."
>> Today's Topics:
>> 1. Installation issue Mapbender 3 (Nelson Lovestrom)
>> 2. Re: Installation issue Mapbender 3 (Charlotte Toma)
>> Message: 1
>> Date: Thu, 3 Aug 2017 13:20:14 -0700
>> From: Nelson Lovestrom <nelson at auracleremotesensing.com>
>> To: mapbender_users at lists.osgeo.org
>> Subject: [Mapbender-users] Installation issue Mapbender 3
>> Message-ID:
>> <CAFT3dytPVF95Q7uJkrkXfK4xKqHwg8vdNY9H34PQApVty8LrfQ at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Having an issue with getting mapbender 3 up and running.
>> I have Apache24 64 bit. and PHP 5.6 64 bit.
>> I've configured both of those correctly to talk to each other.
>> I've went through the steps to install mapbender3 as found here.
> https://doc.mapbender3.org/en/book/installation/installation_windows.html
>> [2]
>> When I get to this part
>> c:
>> cd mapbender3
>> php.exe app/console doctrine:database:create
>> php.exe app/console doctrine:schema:create
>> php.exe app/console assets:install web
>> php.exe app/console fom:user:resetroot
>> php.exe app/console doctrine:fixtures:load
> --fixtures=./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Epsg/
>> --append
> --fixtures=./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Application/
>> --append
>> the first php.exe line throws a fatal error with the message 'You
>> have
>> requested a non-existent parameter "database_host".
>> How do I fix this and get Mapbender running?
>> Nelson Lovestrom
>> B.A., P.G. Dip.
>> GIS Technician
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL:
> <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170803/83a527af/attachment-0001.html
>> [3]>
>> Message: 2
>> Date: Fri, 4 Aug 2017 09:50:37 +0200
>> From: Charlotte Toma <charlotte.toma at wheregroup.com>
>> Subject: Re: [Mapbender-users] Installation issue Mapbender 3
>> Message-ID: <5d112440-79cc-d142-d10d-d21baf401c7b at wheregroup.com>
>> Good morning,
>> the "non-existent parameter" database_host is from the database
>> definition in the parameters.yml (app/config). You propably defined
>> a
>> false value in the database connection in the config.yml
>> parameters:
>> # database-connection "default"
>> database_driver: pdo_pgsql
>> database_host: localhost
>> database_port: 5432
>> database_name: mapbender3
>> database_path: ~
>> database_user: postgres
>> database_password: postgres
>> Documentation is here:
>> https://doc.mapbender3.org/en/book/database.html [4]
>> Mit freundlichen Grüßen
>> Charlotte Toma
>> GIS-Consultant
>> FOSS Academy Sommerschule 2017
>> Aufbau von Geodateninfrastrukturen mit Open-Source-Software
>> 11.-15. September 2017
>> www.foss-academy.com/sommerschule [5]
>> Charlotte Toma
>> WhereGroup GmbH & Co.KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 24 [6]
>> Fax: +49(0)228 90 90 38 - 11 [7]
>> www.wheregroup.com [8]
>> Folgen Sie der WhereGroup auf twitter:
>> http://twitter.com/WhereGroup_com [9]
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> Am 03.08.2017 um 22:20 schrieb Nelson Lovestrom:
>>> here.
>> [2]
>>> c:
>>> cd mapbender3
>> --append
>> --append
>> have
>>> Nelson Lovestrom
>>> B.A., P.G. Dip.
>>> GIS Technician
>>> Mapbender_users at lists.osgeo.org
>> URL:
> <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170804/2e526c82/attachment-0001.html
>> [10]>
>> Subject: Digest Footer
>> End of Mapbender_users Digest, Vol 129, Issue 1
> Nelson Lovestrom
> B.A., P.G. Dip.
> GIS Technician
> Links:
> [1] https://lists.osgeo.org/mailman/listinfo/mapbender_users
> [2]
> [3]
> [4] https://doc.mapbender3.org/en/book/database.html
> [5] http://www.foss-academy.com/sommerschule
> [6] tel:%2B49%280%29228%2090%2090%2038%20-%2024
> [7] tel:%2B49%280%29228%2090%2090%2038%20-%2011
> [8] http://www.wheregroup.com
> [9] http://twitter.com/WhereGroup_com
> [10]
Astrid Emde
GIS-Consultant
Astrid Emde
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_users
