[Mapbender-users] Mapbender GUI and maps are extremely slow
prototron
abrabacabra at openmailbox.org
Wed Feb 8 06:13:23 PST 2017
Thank you!
I did try the nightly (and also previous versions). The applications
seem to work much better. But the GUI to create apps, add sources,
users, etc. seems "broken", like plain HTML, no CSS, JS, PHP...
I just downloaded the tar/gz, unpacked it and copied and overwrite the
files in the installation directory.
Do you have an idea?
On 2017-02-07 4:53 AM, Astrid Emde (WhereGroup) [via OSGeo.org] wrote:
> Hello,
> you could go back to version 3.0.4 http://mapbender3.org/builds/
> But it makes more sense to use the nightly.
> http://mapbender3.org/builds/nightly/
> We are working on the next release. Which should come out in the next
> weeks.
> Astrid
> Am 2017-01-31 14:33, schrieb prototron:
> > Thank you Astrid, I sure will try another version. Before proceeding
> > I would like to know if the problem existed in versions before
> > 3.0.5.3? I may consider downgrading to the latest version without the
> > performance issue instead of using a Nightly build
> > Regards,
> > Pat
> > On 31/01/17 02:53 AM, Astrid Emde (WhereGroup) [via OSGeo.org] wrote:
> >> Hi,
> >> we had a performance problem on windows for Mapbender3 3.0.5.3.
> >> You will get a better performance with the next version.
> >> If you want to try it with the nightly you can download it here:+
> >> Read how to update Mapbender here:
> >> http://doc.mapbender3.org/en/book/installation/update.html
> >> Best regards Astrid
> >> Am 2017-01-31 03:41, schrieb prototron:
> >>> Hello,
> >>> I recently installed Mapbender3 with the ms4w 3.1.4 bundle (along
> >> with
> >>> OpenLayers, Mapserver, Apache, GeoMoose).
> >>> It is installed on a server on the LAN. It does have IIS installed
> >> to
> >>> on
> >>> port 80, but Apache is listening on port 8079. The server has a
> >> Xeon
> >>> 3.4 ghz
> >>> quad-core CPU and 8 gb RAM.
> >>> The WMS/WFS services are working fine.
> >>> I created my first application and I noticed that it was very very
> >> very
> >>> slow... to the point where it is simply unusable.
> >>> The GUI is slow, but usable, like over an low-average internet
> >>> connection.
> >>> When I start the app, it takes about 20-30 seconds to load.
> >>> It seems to already have a ticket opened for that issue, but maybe
> >> it's
> >>> not
> >>> a bug and I just need to change a few settings in the config file.
> >>> Does anybody have an idea where to start to diagnose the problem?
> >>> Mapbender looks very awesome and I would be very pleased that my
> >>> co-workers
> >>> could use it! :)
> >>> View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Mapbender-GUI-and-maps-are-extremely-slow-tp5305423.html
> >>> Sent from the mapbender-users mailing list archive at Nabble.com.
> >>> _______________________________________________
> >>> Mapbender_users mailing list
> >>> [hidden email] [1]
> >>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> >> Mit freundlichen Grüßen
> >> Astrid Emde
> >> GIS-Consultant
> >> FOSS Academy Winterschule 2017
> >> 20.-24.03.2017 in Bonn
> >> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
> >> Astrid Emde
> >> WhereGroup GmbH & Co.KG
> >> Eifelstraße 7
> >> 53119 Bonn
> >> Germany
> >> Fon: +49(0)228 90 90 38 - 22
> >> Fax: +49(0)228 90 90 38 - 11
> >> [hidden email] [2]
> >> www.wheregroup.com [3]
> >> Folgen Sie der WhereGroup auf twitter:
> >> http://twitter.com/WhereGroup_com
> >> Amtsgericht Bonn, HRA 6788
> >> Komplementärin:
> >> WhereGroup Verwaltungs GmbH
> >> vertreten durch:
> >> Olaf Knopp, Peter Stamm
> >> pgp-public key:
> >> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> >> Signierte und/oder verschlüsselte Nachrichten sind sehr
> >> willkommen
> >> Signed and/or encrypted mail is highly appreciated
> >> [hidden email] [4]
> >> If you reply to this email, your message will be added to the
> >> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Mapbender-GUI-and-maps-are-extremely-slow-tp5305423p5305435.html
> >> To unsubscribe from Mapbender GUI and maps are extremely slow,
> >> click here.
> >> NAML [5]
> > View this message in context: Re: Mapbender GUI and maps are
> > extremely slow [6]
> > Sent from the mapbender-users mailing list archive [7] at Nabble.com.
> > Links:
> > [1]
> http://troubadix.wheregroup.com/user/SendEmail.jtp?type=node&node=5305435&i=0
> <http://troubadix.wheregroup.com/user/SendEmail.jtp?type=node&node=5305435&i=0>
> > [2]
> http://troubadix.wheregroup.com/user/SendEmail.jtp?type=node&node=5305435&i=1
> <http://troubadix.wheregroup.com/user/SendEmail.jtp?type=node&node=5305435&i=1>
> > [3] http://www.wheregroup.com
> > [4]
> http://troubadix.wheregroup.com/user/SendEmail.jtp?type=node&node=5305435&i=2
> <http://troubadix.wheregroup.com/user/SendEmail.jtp?type=node&node=5305435&i=2>
> > [5]
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> > [6]
> http://osgeo-org.1560.x6.nabble.com/Mapbender-GUI-and-maps-are-extremely-slow-tp5305423p5305488.html
> > [7] http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
> > [hidden email] </user/SendEmail.jtp?type=node&node=5306693&i=0>
> Astrid Emde
> GIS-Consultant
> Astrid Emde
> Eifelstraße 7
> 53119 Bonn
> Germany
> [hidden email] </user/SendEmail.jtp?type=node&node=5306693&i=1>
> www.wheregroup.com
> Komplementärin:
> vertreten durch:
> pgp-public key:
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> [hidden email] </user/SendEmail.jtp?type=node&node=5306693&i=2>
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/Mapbender-GUI-and-maps-are-extremely-slow-tp5305423p5306693.html
> To unsubscribe from Mapbender GUI and maps are extremely slow, click
> here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5305423&code=YWJyYWJhY2FicmFAb3Blbm1haWxib3gub3JnfDUzMDU0MjN8LTY2MDQ1MjY0OA==>.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbender-GUI-and-maps-are-extremely-slow-tp5305423p5306958.html
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170208/89992b07/attachment-0001.html>
More information about the Mapbender_users
