[Mapbender-users] mb3: Digitizer / Trigger Problem
Astrid Emde
astrid.emde at wheregroup.com
Tue Feb 7 02:00:04 PST 2017
Hello,
does your table contains oids?
You should use a table without without oids.
There is also a new digitizer version coming soon with the new
Mapbender3 version. The problem should be fixed there.
Astrid
Am 2017-01-30 17:11, schrieb v.botz:
> Hi,
> i want to use mapbender 3 for an attribute editing tool.
>> change attributes on geometries via a gui...
> *in principel it works fine with the digitizer function. *
> *But if i use a trigger / function on the table i am editing, i got
> errors
> (without trigger everything is fine).*
> If i start the trigger with sql it works fine!
> *Error in dev log: emergency: Call to a member function getId() on
> boolean...*
> My Trigger / Function:
> CREATE TRIGGER a_delete_el_alle
> AFTER UPDATE
> ON weinbau_edit.el_alle_alkis_liste
> FOR EACH ROW
> EXECUTE PROCEDURE a_delete_el_alle();
> CREATE OR REPLACE FUNCTION a_delete_el_alle() RETURNS TRIGGER AS $$
> BEGIN
> INSERT INTO weinbau_edit.el_alle_alkis (code, the_geom,
> wlg_nr,
> erfasser, stand)
> (select code, NEW.the_geom, NEW.wlg_nr, 'engisch_gis', now() from
> weinbau_edit.el_alle_alkis_liste where code = NEW.code);
> delete from weinbau_edit.el_alle_alkis_liste where code = NEW.code;
> RETURN NULL;
> END;
> $$ LANGUAGE plpgsql;/
> Has anyone an idea what the problem is ???
> Thanx Volk.
> http://osgeo-org.1560.x6.nabble.com/mb3-Digitizer-Trigger-Problem-tp5305326.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Winterschule 2017
20.-24.03.2017 in Bonn
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users
