[Mapbender-users] mb3: Digitizer / Trigger Problem
v.botz volker.emmel at lwk-rlp.de
Fri Feb 10 00:15:45 PST 2017
thanks for the note, changed from oid to gid, but it doesn't fix the
problem.
i think it is a problem with the delete statement, without if works fine....
dev.log:
[2017-02-10 09:12:05] doctrine.DEBUG: SELECT column_name FROM
information_schema.columns WHERE (table_schema || '.' || table_name =
'weinbau_edit.el_alkis_liste' OR table_name = 'weinbau_edit.el_alkis_liste')
ST_TRANSFORM(ST_GEOMFROMTEXT('SRID=25832;MULTIPOLYGON(((407733.64699998
5558118.6469996,407732.75999998 5558104.9959996,407762.99499998
5558104.5569996,407733.64699998 5558118.6469996)))'), 25832) [] []
[2017-02-10 09:12:05] doctrine.DEBUG: UPDATE weinbau_edit.el_alkis_liste SET
wlg_nr = ?, the_geom = ? WHERE gid = ? ["320505","0106000020E864000001000000
[...]",70] []
[2017-02-10 09:12:05] doctrine.DEBUG: SELECT gid,
ST_ASTEXT(ST_TRANSFORM(the_geom, 25832)) AS the_geom, code, wlg_nr, prozent,
gid FROM weinbau_edit.el_alkis_liste t WHERE gid = :id {"id":70} []
[2017-02-10 09:12:05] emergency.EMERGENCY: Call to a member function getId()
on boolean
{"type":1,"file":"/var/www/html/mapbender3/vendor/mapbender/digitizer/Mapbender/DigitizerBundle/Element/Digitizer.php","line":229}
in this case, i could wait for the next release ;-)
thanks V°
View this message in context: http://osgeo-org.1560.x6.nabble.com/mb3-Digitizer-Trigger-Problem-tp5305326p5307325.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
