[Mapbender-users] mapbender3: Digitizer / Skript error / nightly build
v.botz
volker.emmel at lwk-rlp.de
Fri Feb 10 03:22:17 PST 2017
i am editing Attributes via the Digitizer-Fuction. In principle in works
fine.
-> i have upgraded to the last nightly version, because in the stable
version 3.0.5.3 i got (while editing) the warning: Skript antwortet nicht
(skript doesnt answer) Skript: http......./assets/js:2471
--> because of another post i tried the nightly version.
> now there is no problem with the skript (everything is fast), but
- Editing in the starting BoundingBox works fine
-> but if i change the BoundingBox via Search i loose the connection
between attribute table and map.
means: no geometries in the map could be selected via mouse, no dialog
windows appears if i click in the map
the geometries in the attribute table are correct
(depending to the bounding box)
any idea how i could fix this?
is this problem known?
greeting V°
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapbender3-Digitizer-Skript-error-nightly-build-tp5307391.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users
