[Mapbender-users] Fwd: Problems (Permission maybe)
GUILLERMO HEUFEMANN FRITZ
guillermo.heufemann at gmail.com
Fri Feb 24 06:41:33 PST 2017
Estimado Sr Jochen Schultz,
En la ruta http://localhost/app_dev.php/application/manager/assets/css
<http://localhost/app_dev.php/_configurator/> se muestra estos errores.
1. DEBUG - Notified event "kernel.request" to listener
"Symfony\Component\HttpKernel\EventListener\ProfilerListener::onKernelRequest".
2. DEBUG - Notified event "kernel.request" to listener "Symfony\Bundle\
FrameworkBundle\EventListener\SessionListener::onKernelRequest".
3. DEBUG - Notified event "kernel.request" to listener
"Symfony\Component\HttpKernel\EventListener\RouterListener::onKernelRequest".
4. DEBUG - Notified event "kernel.exception" to listener
"Symfony\Component\HttpKernel\EventListener\ProfilerListener::onKernelException".
5. DEBUG - Notified event "kernel.exception" to listener
"Symfony\Component\HttpKernel\EventListener\ExceptionListener::onKernelException".
6. ERROR - Uncaught PHP Exception
Symfony\Component\HttpKernel\Exception\NotFoundHttpException:
"No route found for "GET /app_dev/application/manager/assets/css"" at
/var/www/mapbender3/app/cache/dev/classes.php line 1887
7. DEBUG - Notified event "kernel.request" to listener "closure".
8. DEBUG - Notified event "kernel.request" to listener
9. DEBUG - Notified event "kernel.request" to listener "closure".
10. DEBUG - Notified event "kernel.request" to listener "Symfony\Bundle\
11. DEBUG - Notified event "kernel.request" to listener "closure".
12. DEBUG - Notified event "kernel.request" to listener
13. DEBUG - Notified event "kernel.request" to listener "closure".
14. DEBUG - Notified event "kernel.request" to listener
"Symfony\Component\HttpKernel\EventListener\LocaleListener::onKernelRequest".
15. DEBUG - Notified event "kernel.request" to listener "closure".
16. DEBUG - Notified event "kernel.request" to listener
"Symfony\Component\Security\Http\Firewall::onKernelRequest".
17. DEBUG - Notified event "kernel.request" to listener "closure".
18. DEBUG - Notified event "kernel.request" to listener
"Symfony\Bundle\AsseticBundle\EventListener\RequestListener::onKernelRequest".
19. DEBUG - Notified event "kernel.request" to listener "closure".
20. DEBUG - Notified event "kernel.request" to listener
"Symfony\Component\HttpKernel\EventListener\ErrorsLoggerListener::injectLogger".
21. DEBUG - Notified event "kernel.request" to listener "closure".
22. DEBUG - Notified event "kernel.request" to listener
23. DEBUG - Notified event "kernel.controller" to listener
"Symfony\Bundle\FrameworkBundle\DataCollector\RouterDataCollector::onKernelController".
24. DEBUG - Notified event "kernel.controller" to listener
"Symfony\Component\HttpKernel\DataCollector\RequestDataCollector::onKernelController".
25. DEBUG - Notified event "kernel.controller" to listener
"Sensio\Bundle\FrameworkExtraBundle\EventListener\ControllerListener::onKernelController".
26. DEBUG - Notified event "kernel.controller" to listener
ParamConverterListener::onKernelController".
27. DEBUG - Notified event "kernel.controller" to listener
"Sensio\Bundle\FrameworkExtraBundle\EventListener\TemplateListener::onKernelController".
Adjunto imagen del navegador
Trabajo con CentOS 7
He ejecutado esto,
cd /var/www/mapbender3
app/console doctrine:database:create
app/console doctrine:schema:create
app/console assets:install web
app/console fom:user:resetroot
app/console doctrine:fixtures:load
--fixtures=./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Epsg/
--append
--fixtures=./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Application/
--append
sudo chmod -R ug+w /var/www/mapbender3/app/cache
sudo chmod -R ug+w /var/www/mapbender3/app/logs
sudo chmod -R ug+w /var/www/mapbender3/web/uploads
He seguido los pasos de
http://doc.mapbender3.org/en/book/installation/installation_ubuntu.html.
Ya hice una instalación en debian y funciona
http://rukamanke.cmcc.ufro.cl/mapbender3/app.php.
Quizás sea un problema de configuración de apache en CentOS, seguiré
intentando.
Muchas gracias por la ayuda que me está brindando.
Saludos
2017-02-24 9:15 GMT-03:00 Jochen Schultz <jochen.schultz at wheregroup.com>:
> Estimado Sr. Guillermo Heufemann,
> podria abrir la ruta http://localhost/app_dev.php/
> <http://localhost/app_dev.php/_configurator/> su navegador y mostrarme el
> mensaje de error?
> Usted trabaja con Windows?
> Usted ha ejecutado
> c:
> cd mapbender3
> php.exe app/console doctrine:database:create
> php.exe app/console doctrine:schema:create
> php.exe app/console assets:install web
> php.exe app/console fom:user:resetroot
> php.exe app/console doctrine:fixtures:load --fixtures=./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Epsg/ --append
> php.exe app/console doctrine:fixtures:load --fixtures=./mapbender/src/Mapbender/CoreBundle/DataFixtures/ORM/Application/ --append
> en su consola (cmd)?
> Usted trabaja con Linux?
> Usted ha ejecutado
> en su consola?
> Saludos, Jochen Schultz
> Am 23.02.2017 um 18:28 schrieb GUILLERMO HEUFEMANN FRITZ:
> ---------- Forwarded message ---------- From: GUILLERMO HEUFEMANN FRITZ <
> guillermo.heufemann at gmail.com> Date: 2017-02-23 12:30 GMT-03:00 Subject:
> Re: [Mapbender-users] Problems (Permission maybe) To: Jochen Schultz <
> Estimado Jochen Schultz,
> Estoy intentando instalar mapbender3-3.0.5.3 siguiendo las indicaciones de
> http://doc.mapbender3.org/en/book/installation.html, desde cero, he leído
> la documentación pero aún así no logro dar con el problema.
> El IP del servidor es lts.ufro.cl
> (google traductor): I am trying to install mapbender3-3.0.5.3 following the instructions at http://doc.mapbender3.org/en/book/installation.html, from scratch,
> i have read the documentation but still can not find the problem. The server IP is lts.ufro.cl
> 2017-02-23 11:16 GMT-03:00 Jochen Schultz <jochen.schultz at wheregroup.com>:
>> Estimado Sr. Guillermo Heufemann, lo siento, yo hablo muy poco espanol.
>> > I have this advice in http://localhost/app_dev.php/_configurator/ De
>> donde ha recibido usted está información? Usted ha leído la documentatión?
>> De que se trata? Ha instalado el Mapbender por primera (que versión de
>> Mapbender ha instalado usted y como lo ha hecho?) vez o haya cambiado una
>> aplicación existente? Saludos, Jochen Schultz
>> translation: Where did you get this information? Did you read the
>> documentation? What is this about? Did you install Mapbender initially
>> (which version of Mapbender and how did you install it?) or did you change
>> an existing application?
>> Am 23.02.2017 um 06:51 schrieb GUILLERMO HEUFEMANN FRITZ:
>> Hi! (my english is bad, my primary language is spanish)
>> "Symfony\Bundle\FrameworkBundle\EventListener\SessionListener::onKernelRequest".
>> 6. ERROR - Uncaught PHP Exception Symfony\Component\HttpKernel\E
>> xception\NotFoundHttpException: "No route found for "GET
>> /_configurator/"" at /var/www/mapbender3/app/cache/dev/classes.php
>> line 1887
>> "Sensio\Bundle\FrameworkExtraBundle\EventListener\ParamConve
>> I tried everything.
>> Help me please.
>> PD: In localhost/app.php display the page, but without .css, white
>> background, etc.
>> Guillermo Richard Heufemann Fritz
>> Ingeniero Civil Industrial, *UFRO*.
>> +56 9 57690211
>> Mapbender_users mailing listMapbender_users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapbender_users
>> FOSS Academy Winterschule 2017
>> 20.-24.03.2017 in Bonn
>> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
>> Viele Grüße
>> Jochen Schultz
>> WhereGroup GmbH & Co. KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 - 44
>> Fax: +49 (0)228 / 90 90 38 - 11
>> jochen.schultz at wheregroup.comwww.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
> +56 9 57690211
> +56 9 57690211
> Viele Grüße
> Jochen Schultz
> Eifelstraße 7
> 53119 Bonn
> Germany
> Komplementärin:
> vertreten durch:
+56 9 57690211
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170224/b1217ed2/attachment-0001.html>
Name: mapb error.PNG
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170224/b1217ed2/attachment-0001.png>
More information about the Mapbender_users
