[Mapbender-users] MapBender3 Zoom To Layer problems
Simone Micozzi micozzi.simone749 at tiscali.it
Tue Jan 3 06:23:39 PST 2017
Hi, Astrid.
No, for now it is a local installation not accessible from "outside".
As soon as I'll be on the machine I'll check the GeoServer response
and the max_extent settings in the map element.
Thank you for the advice.
Simone
Il giorno 03/gen/17, alle ore 11:15, Astrid Emde ha scritto:
> Hello Simone,
> is the GeoServer WMS a public Service so we could have a look at the
> extent of the layers?
> Does your max_extent (from map element) is big enough so ZOOM TO
> LAYER EXTENT would jump to an area within the max_extent?
> Best regards Astrid
> Am 2017-01-03 09:46, schrieb Simone Micozzi:
>> Hello, Mapbender Users
>> and Happy New Year to you all!
>> I set up a web GIS system based on Mapbender3
>> and backed by Geoserver and PostGis.
>> All is working fine and first of all I want to thank you
>> all Mapbender developer for the wonderful software
>> they shared with the web community.
>> I am experiencing some problems
>> with the ZOOM TO LAYER EXTENT function
>> in the Layertree panel.
>> In GeoServer, when I load the same layers with the Layer Preview
>> the layers' bounding boxes are correctly found,
>> so the spatial infos are accurate.
>> On the contrary, when I click on the Zoom To Layer icon
>> in the LayerTree panel in Mapbender,
>> the map is positioned uncorrectly,
>> like if it there was some coordinates error.
>> It reminds me of similar problems I experienced sometimes with UMN
>> MapServer,
>> when the base coordinates were in degrees
>> but the approximation of the values was too low.
>> Inside the Map configuration component I have set up the SRS to WGS84
>> (EPSG:4326)
>> and select as measure unit DEGREES,
>> and I set the application extent too.
>> If someone can give me some advice
>> or at least head me in the right direction,
>> I would really appreciate it.
>> Thank you in advance,
>> Simone Micozzi
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> astrid.emde at wheregroup.com
> www.wheregroup.com
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
