[Mapbender-users] MapBender3 Zoom To Layer problems
Astrid Emde
astrid.emde at wheregroup.com
Tue Jan 3 02:15:57 PST 2017
Hello Simone,
is the GeoServer WMS a public Service so we could have a look at the
extent of the layers?
Does your max_extent (from map element) is big enough so ZOOM TO LAYER
EXTENT would jump to an area within the max_extent?
Best regards Astrid
Am 2017-01-03 09:46, schrieb Simone Micozzi:
> Hello, Mapbender Users
> and Happy New Year to you all!
> I set up a web GIS system based on Mapbender3
> and backed by Geoserver and PostGis.
> All is working fine and first of all I want to thank you
> all Mapbender developer for the wonderful software
> they shared with the web community.
> I am experiencing some problems
> with the ZOOM TO LAYER EXTENT function
> in the Layertree panel.
> In GeoServer, when I load the same layers with the Layer Preview
> the layers' bounding boxes are correctly found,
> so the spatial infos are accurate.
> On the contrary, when I click on the Zoom To Layer icon
> in the LayerTree panel in Mapbender,
> the map is positioned uncorrectly,
> like if it there was some coordinates error.
> It reminds me of similar problems I experienced sometimes with UMN
> MapServer,
> when the base coordinates were in degrees
> but the approximation of the values was too low.
> Inside the Map configuration component I have set up the SRS to WGS84
> (EPSG:4326)
> and select as measure unit DEGREES,
> and I set the application extent too.
> If someone can give me some advice
> or at least head me in the right direction,
> I would really appreciate it.
> Thank you in advance,
> Simone Micozzi
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users
