[Mapbender-users] MS4W version 3.2.2 available
Prototron
abrabacabra at openmailbox.org
Thu Jul 13 16:24:52 PDT 2017
This is good news!
Thank you all for you good work! Much appreciated!
On 13/07/17 12:15 PM, Jeff McKenna wrote:
> Hi all! Ready for FOSS4G-Europe, today's release of the MS4W
> installer contains many changes specifically for the Mapbender 3.0.6.1
> release, and it works super fast, give it a try! The 3.0.6.1 package
> is also included in MS4W's setup.exe installer now. Enjoy!! (see
> below for more release notes) -jeff
> -------- Forwarded Message --------
> Hello everyone,
> MS4W version 3.2.2 is now available at http://www.ms4w.com This
> contains security releases of Apache, PHP, and upgrades to the
> MapServer 7.0.6 & GDAL 2.2.1 releases. Several changes were also made
> to libraries for performance improvements (such as libjpeg-turbo and
> SQLite). Several packages were upgraded for the installer including
> GeoMOOSE 3.0.0-beta (new backend engine, give it a try!), Mapbender
> 3.0.6.1 (now super fast), OpenLayers 4.2.0 (when you goto the
> OpenLayers examples page and search for "mapserver" you can find a
> local MS4W example). This a substantial MS4W release. Here is the
> full list of changes:
> - upgraded MapServer and MapScript (CSharp, Java, Python, PHP) to
> 7.0.6
> - upgraded GDAL to 2.2.1 (trac ticket 111)
> - upgraded PHP to 5.6.31 (trac ticket 122)
> - upgraded Apache to 2.4.27 (trac ticket 119)
> - enabled OPcache PHP extension for Mapbender performance (trac
> ticket 63)
> - built MapServer with support for Z geometry values (trac ticket 120)
> - updated cURL certificates bundle
> - rebuilt mod_fcgid
> - rebuilt Apache H264 Streaming Module
> - rebuilt MapCache
> - rebuilt TinyOWS
> - changed JPEG library to libjpeg-turbo (trac ticket 121)
> - upgraded libPNG support to 1.6.29
> - upgraded libTIFF support to 4.0.8 (trac ticket 114)
> - upgraded GeoTIFF support to SVN-trunk-20170623
> - rebuilt HDF4 support
> - upgraded HDF5 support to 1.10.1
> - upgraded PostgreSQL support to 9.6.3
> - upgraded MySQL support to 5.7.18
> - upgraded SQLite support to 3.19.3 (trac ticket 107)
> - rebuilt SpatiaLite support
> - upgraded OpenSSL support to 1.0.2l (trac ticket 116)
> - upgraded cURL support to 7.54.1
> - added curl.exe utility into /tools
> - rebuilt NetCDF support
> - upgraded Freetype support to 2.8
> - upgraded Cairo support to 1.14.10
> - rebuilt Poppler support
> - upgraded to Esri File Geodatabase 1.5 API support (trac ticket 109)
> - upgraded to Oracle SDK 12.2.0.1.0
> - upgraded PCRE support to 8.40
> - upgraded HarfBuzz support to 1.4.6
> - rebuilt libSVG support
> - rebuilt libSVG-Cairo support
> - upgraded Shapelib support to 1.4.0 (trac ticket 72)
> - rebuilt shp2tile utility
> - renamed Apache access and error log files
> Please note that (if you are using the .zip) your server must have the
> C++ Redistributable installed on it beforehand: execute the local file
> /ms4w/tmp/vcredist_x86.exe
> Please don't be afraid to also provide feedback and requests through
> the MS4W tracker (so the comments and requests are not lost or
> forgotten): http://www.ms4w.com/trac/
> Thank you all for sharing your spatial information with MS4W.
> And happy MapServing!
> -jeff
More information about the Mapbender_users
