[Mapbender-users] Get Raster Info and more
Simone Micozzi micozzi.simone749 at tiscali.it
Fri Mar 31 01:27:36 PDT 2017
Ciao, Ben,
and thank you for your kind replay.
Not even I am so much into Geoserver.
As a matter of fact, this is the first project in which I'm using it,
and starting to appreciate it.
Till now I have always been (and I still intend to be)
a loyal - and satisfied! - user of UMN Mapserver.
Anyway,
after a little bit of testing
I have seen that Mapbender is correctly displaying
the legend generated by Geoserver.
But I haven't yet figured out a way
for attaching my own set of metadata to my raster files
and having them displayed by Mapbender.
Selecting the info (metadata) icon of these raster files in the
layertree box
only causes to display some standard Geoserver metadata
that are not so significant to me.
I even tried some tricks to get around Geoserver,
like "wrapping" my rasters into a mosaic,
so to take advantage of the generated DBF file
and putting my metadata inside of it.
But Geoserver didn't take the bait
and in the GetFeatureInfo box in Mapbender
it's just showing the pixel related metadata (like grayscale ratio and
so on).
Perhaps this is not the right place to address a question like this,
but I thought that maybe someone had faced the same problem before,
and solved it!
Thank you anyway for your time.
I will certainly take a look at the links you have shown me
and try to take the best out of them.
Cordialmente,
Simone Micozzi
Il giorno 30/mar/17, alle ore 13:29, Schepers, Benjamin ha scritto:
> Hi Simone,
> You asked for some hints: I really need in my application to get
> some info about the raster layers, in particular a legend with the
> color scale and some associated metadata (these raster files are the
> results of various processing chains performed on satellite data).
> --> from my point of view the mentioned things are are to be done on
> the wms-server-side. (GetLegend-/GetFeatureInfo-Request), Mapbender
> just shows the response of the mentioned requests with Info- or
> legend-icon - also for raster-data.
> I'm sorry that I can't help you further, because I'm not into
> GeoServer. But I know this could be done with UMN-Mapserver.
> MapServer and GeoServer are nearly always capable to do the same
> things, so I would expect that this is possible with GeoServer too.
> Maybe these links help:
> http://docs.geoserver.org/2.7.0/user/services/wms/get_legend_graphic/legendgraphic.html
> http://docs.geoserver.org/latest/en/user/services/wms/reference.html#getfeatureinfo
> http://docs.geoserver.org/latest/en/user/tutorials/GetFeatureInfo/index.html#tutorials-getfeatureinfo
> Cheers,
> Ben
> Mit freundlichen Grüßen
> Im Auftrag
> Benjamin Schepers
> Geodaten, Stadtplanwerk, Luftbilder
> Kronprinzenstraße 6
> 45128 Essen
> Fon: +49 201 2069-232
> Fax: +49 201 2069-369
> schepers at rvr-online.de
> Die Regionaldirektorin
> Kronprinzenstraße 35
> 45128 Essen
> Zentrale: +49 (0) 201 2069-0
> Fax: +49 (0) 201 2069-500
> www.metropoleruhr.de
> Postfach 10 32 64
> 45032 Essen
> Steuernummer: RVR 112/5797/0116
> USt.-ldNr.: DE 173867500
> Diese E-Mail koennte vertrauliche und/oder rechtlich geschuetzte
> Informationen enthalten.
> Wenn Sie nicht der richtige Adressat sind oder diese E-Mail
> irrtuemlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten Sie diese Mail.
> Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail
> sind nicht gestattet.
> This e-mail may contain confidential and/or privileged information.
> If you are not the intended recipient (or have received this e-mail
> in error) please notify the sender immediately and destroy this e-
> mail.
> Any unauthorised copying, disclosure or distribution of the material
> in this e-mail is strictly forbidden.
> -----Ursprüngliche Nachricht-----
> Von: Mapbender_users [mailto:mapbender_users-
> bounces at lists.osgeo.org] Im Auftrag von Simone Micozzi
> Gesendet: Donnerstag, 9. März 2017 10:21
> An: Astrid Emde
> Cc: Mapbender User List
> Betreff: Re: [Mapbender-users] Get Raster Info and more
> Ciao, Astrid,
> and thank you for your reply.
> I noticed that you didn't mention the first point in my email.
> Maybe because it is a silly question?
> GetFeatureInfo from a raster layer...
> I really need in my application to get some info about the raster
> layers, in particular a legend with the color scale and some
> associated metadata (these raster files are the results of various
> Is it possible to use the metedata icon in the LayerTree panel to
> link to an external source (a HTML or XML document, or a DB table
> maybe)?
> And if so, could you give me some advice about that?
> Forgive my insistence, but this is really important to me.
> Thank you anyway,
> Simone
> Il giorno 08/mar/17, alle ore 18:33, Astrid Emde ha scritto:
>> Hello,
>> Am 2017-03-07 02:05, schrieb Simone Micozzi:
>>> Hi to all.
>>> I set up a webgis application based on PostGIS, GeoServer and
>>> MapBender.
>>> The connections between the three components work fine:
>>> the layers are regularly displayed by MapBender and when you click
>>> on
>>> a feature inside the map (after having selected the FeatureInfo
>>> button) a dialog box shows up displaying the related data.
>>> Now, what I would like to do is to have the same result clicking
>>> on a
>>> raster file, except that the info displayed would be of another
>>> kind,
>>> maybe a legend and/or some related metadata.
>>> Is it possible? And, if it is, could anyone point me where to find
>>> some example or some guide about it?
>>> Another thing I need to learn is how to style the Welcome Page and
>>> also the FeatureInfo dialog box.
>> Style the featureInfo Box
>> Have a look at how to make your own template.
>> http://doc.mapbender3.org/en/book/templates.html
>> Note that the result comes from a WMS. SO maybe you have to style
>> Geoserver result too.
>> Style the welcome page:
>> You can overwrite the manager.html.twig file.
>> It works like this in Symfony.
>> 1. Create the file structure to where the file is located f.e
>> /app/Resources/FOMManagerBundle/views/
>> 2. Copy the file from the origin location to this location
>> cp fom/src/FOM/ManagerBundle/Resources/views/manager.html.twig app/
>> 3. now you can add a new css to you twig
>> <link rel="stylesheet" href="{{ asset('bundles/workshopdemo/
>> manager.css') }}"/>
>> 4. Overwrite Information from the original style or change the twig
>> structure
>> You find a sample manager.css in the workshop bundle.
>> https://github.com/mapbender/mapbender-workshop/tree/master/src/
>> Worksh
>> op/DemoBundle/Resources/public
>> Please note. This works for Mapbender 3.0.5.3.
>> Astrid
>>> Thank you in advance for every possible help, Simone Micozzi
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Astrid Emde
>> GIS-Consultant
>> FOSS Academy Winterschule 2017
>> 20.-24.03.2017 in Bonn
>> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
>> Astrid Emde
>> WhereGroup GmbH & Co.KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 22
>> Fax: +49(0)228 90 90 38 - 11
>> astrid.emde at wheregroup.com
>> www.wheregroup.com
>> Folgen Sie der WhereGroup auf twitter:
>> http://twitter.com/WhereGroup_com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> pgp-public key:
>> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>> Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
