[Mapbender-users] Changes server for www and docs.mapbender3.org
Axel Schaefer axel.schaefer at wheregroup.com
Fri May 19 04:10:38 PDT 2017
Dear Mapbender-Users.
We have switched servers for www.mapbender3.org and docs. If you
encounter some problems, please let us know. The website will be
adjusted shortly.
Here are the links:
- www.mapbender3.org: Mapbender3 Website
- www.mapbender.org: Mapbender3 Website (redirects a bit strange, yet)
The documentation. We have two subdomains, doc and docs (plural). Doc is
the current doc and docs let you choose between different versions.
- doc.mapbender3.org: The current released documentation, as always.
- docs.mapbender3.org: redirects to docs.mapbender3.org/current
- docs.mapbender3.org/current: the current released documentation
- docs.mapbender3.org/3053: documentation for version 3.0.5.3
- docs.mapbender3.org/3052: documentation for version 3.0.5.2
- docs.mapbender3.org/3051: documentation for version 3.0.5.1
- docs.mapbender3.org/3050: documentation for version 3.0.5.0
- docs.mapbender3.org/304: documentation for version 3.0.4.x
We are going to create another server for the current builds of the
documentation on our test-system and I will inform you for that later.
Best regards,
Axel
Axel Schaefer
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 23
Fax: +49 (0)228 / 90 90 38 - 11
www.meldemax.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
