[Mapbender-users] Custom element that displays the result of a SQL query
Abrabacabra
abrabacabra at openmailbox.org
Tue May 30 16:37:21 PDT 2017
I am a little confused on how to install the bundle and add the element
in one of my applications.
I downloaded the source from the git repo and put it in
//vendor/mapbender/query-builder/.
Then I ran //composer.phar require //"mapbender/query-builder"./
It installed a few dependencies but failed near the end (I didn't wrote
down the error :/). I ran the previous command another time and now it
says that nothing was installed, nothing was updated and there is no
error message.
Still can't see the element though..
I backed up the whole Mapbender folder before doing it, so I could do it
again and provide more information if needed.
Anyway, am I missing something? Is it that simple to install the bundle?
On 2017-05-30 1:05 AM, Schepers, Benjamin wrote:
> Hi Pat,
> mabybe this is what you want:
> https://github.com/mapbender/query-builder
> To be honest, I didn’t try it by myself. But I’d appreciate it, if you
> try it and share your experiences ;-)
> Regards
> Ben
> *Von:*Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org]
> *Im Auftrag von *Abrabacabra
> *Gesendet:* Donnerstag, 25. Mai 2017 04:34
> *An:* mapbender_users at lists.osgeo.org
> *Betreff:* Re: [Mapbender-users] Custom element that displays the
> I simply need to display, maybe in the toolbar or something, a single
> dynamic numeric value based on the result of a query made to the
> PostgreSQL database we use for the daily operations of the organization.
> It would be preceded by a string like: "The value is:" ([value])
> Is there a currently available element/bundle that allows us to do that?
> On 2017-05-24 4:30 AM, Uwe Seher wrote:
> Hello!
> You should provide a little more information what you want to do.
> You can use different approches to solve this. In mapbender i
> think, you can use something like the search or the digitizer
> element. These can use a sql-query direct from mapbender. You only
> have to configure the database connection. But when you use a wms
> layer in the behind, a getfeatureinfo is maybe the better approach.
> best regards
> Uwe Seher
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> <mailto:Mapbender_users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170530/4f3c67e8/attachment.html>
More information about the Mapbender_users
