[Mapbender-users] mapbender - No ACL found for the object identity
GeoLady
mvischranka at gmail.com
Thu Nov 2 04:47:54 PDT 2017
Hi
I'm a newbie to mapbender and need some help. I installed apache 2.4.27, php
7.1.10, mapbender 3.0.6.3 succesfully and connect to my DB oracle 12g works
fine. I used this manual>
https://doc.mapbender3.org/en/book/installation/installation_windows.html
Admin console works fine http://localhost:83/mapbender3/app.php. But when I
add a new wms source
an error occurs (getCapabilities request works fine in browser) >
/[2017-10-30 12:44:57] request.INFO: Matched route
"mapbender_manager_repository_create".
{"route_parameters":{"_controller":"Mapbender\\ManagerBundle\\Controller\\RepositoryController::createAction","managertype":"wms","_route":"mapbender_manager_repository_create"},"request_uri":"http://localhost:83/mapbender3/app.php/manager/repository/create/wms"}
[2017-10-30 12:44:57] security.DEBUG: Read existing security token from the
session. {"key":"_security_secured_area"} []
[2017-10-30 12:44:57] security.DEBUG: User was reloaded from a user
provider.
{"username":"root","provider":"Symfony\\Bridge\\Doctrine\\Security\\User\\EntityUserProvider"}
[2017-10-30 12:44:57] security.DEBUG: No ACL found for the object identity.
Voting to deny access. [] []
[2017-10-30 12:44:59] app.DEBUG: CommonProxy->createBrowser rowUrl:Array (
[scheme] => http [host] => xxx.xxx.x.xxx [port] => xxxx [path]
=> /mapviewer/wms ) [] []
[2017-10-30 12:44:59] app.DEBUG: CommonProxy->handle
GET:http://ipadresse:port/mapviewer/wms?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
[2017-10-30 12:44:59] app.DEBUG: CommonProxy->handle Headers: Array (
[Host] => xxx.xxx.x.xxx) [] []
[2017-10-30 12:45:11] app.ERROR: Element 'WMT_MS_Capabilities': No matching
global declaration available for the validation root. [] []
[2017-10-30 12:45:11] app.ERROR: mb.wms.repository.parser.not_valid_xsd []
[2017-10-30 12:45:11] security.DEBUG: Stored the security token in the
session. {"key":"_security_secured_area"} []/
When I click on "view mapbender demo map" an error occurs >
/[2017-10-30 14:25:16] request.INFO: Matched route
"mapbender_core_application_application".
{"route_parameters":{"_format":"html","_controller":"Mapbender\\CoreBundle\\Controller\\ApplicationController::applicationAction","slug":"mapbender_user","_route":"mapbender_core_application_application"},"request_uri":"http://localhost:83/mapbender3/app.php/application/mapbender_user"}
[2017-10-30 14:25:16] security.DEBUG: Read existing security token from the
[2017-10-30 14:25:16] security.DEBUG: User was reloaded from a user
provider.
[2017-10-30 14:25:17] security.DEBUG: Object identity unavailable. Voting to
grant access. [] []
[2017-10-30 14:25:17] request.CRITICAL: Uncaught PHP Exception
Twig_Error_Runtime: "An exception has been thrown during the rendering of a
template ("ObjectIdentity(layertree-button,
Mapbender\CoreBundle\Entity\Element) is already associated with an ACL.")."
at
D:\MapBender3\mapbender\src\Mapbender\CoreBundle/Resources/views/Template/fullscreen.html.twig
line 33 {"exception":"[object] (Twig_Error_Runtime(code: 0): An exception
has been thrown during the rendering of a template
(\"ObjectIdentity(layertree-button, Mapbender\\CoreBundle\\Entity\\Element)
is already associated with an ACL.\"). at
D:\\MapBender3\\mapbender\\src\\Mapbender\\CoreBundle/Resources/views/Template/fullscreen.html.twig:33,
Symfony\\Component\\Security\\Acl\\Exception\\AclAlreadyExistsException(code:
0): ObjectIdentity(layertree-button, Mapbender\\CoreBundle\\Entity\\Element)
is already associated with an ACL. at
D:\\MapBender3\\vendor\\symfony\\security-acl\\Dbal\\MutableAclProvider.php:55)"}
[2017-10-30 14:25:17] security.DEBUG: Stored the security token in the
session. {"key":"_security_secured_area"} [] /
Why do I have ACL*, MB*, FOM* tabs in oracle empty ? I read mapbender
documentation but I can't move forward. Thank you for help.
GeoLady
Sent from: http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
More information about the Mapbender_users
