[Mapbender-users] query boolean field in search router
Henning Lorenz
henning.lorenz at geo.uu.se
Tue Oct 17 03:18:17 PDT 2017
Hello,
I have problem with querying a boolean field in the search router.
Example:
I have a boolean field (with name 'existing') in may database table that
indicates whether an object is existing (true) or planned (false). I try
to query this with a "type: choice" field, but apparently I can't get
the choices right:
existing:
type: choice
options:
empty_value: 'Please select'
required: false
label: 'Status'
choices:
'true': 'existing'
'false': 'planned'
I tried with and without quotation marks, also in capitals and numbers -
no success. The search results are always empty. (Otherwise, search
router works fine)
I appreciate any help with making this work, either with the correct
'choices' or a different search field type.
Thank you,
Henning
More information about the Mapbender_users
