[Mapbender-users] query boolean field in search router
Charlotte Toma charlotte.toma at wheregroup.com
Thu Oct 19 00:46:47 PDT 2017
Hello Henning,
is your problem still there?
Did you get an error message about the configuration? If you open the
SeachRouter with your configuration in the app_dev.php mode, then a
relatively detailed message should appear in the frontend, that tells
you why he can't display the selectbox correctly.
Perhaps you look at the log-file (app/logs/) or open the developer tools
in the browser.
If the error message doesn't help you, then you can send the related
error in theis list and we try to help you.
Mit freundlichen Grüßen
Charlotte Toma
GIS-Consultant
Where2B Konferenz 2017
14. Dezember 2017 in Bonn
www.where2b-conference.com
Charlotte Toma
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 24
Fax: +49(0)228 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 17.10.2017 um 12:18 schrieb Henning Lorenz:
> Hello,
> I have problem with querying a boolean field in the search router.
> Example:
> I have a boolean field (with name 'existing') in may database table
> that indicates whether an object is existing (true) or planned
> (false). I try to query this with a "type: choice" field, but
> apparently I can't get the choices right:
>   existing:
>     type: choice
>     options:
>       empty_value: 'Please select'
>       required: false
>       label: 'Status'
>       choices:
>         'true': 'existing'
>         'false': 'planned'
> I tried with and without quotation marks, also in capitals and numbers
> - no success. The search results are always empty. (Otherwise, search
> router works fine)
> I appreciate any help with making this work, either with the correct
> 'choices' or a different search field type.
> Thank you,
> Henning
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
