[Mapbender-users] MapBender3.0.6.3 : Using template classic & Full screen don't work
Maelle Vercauteren mavercau at ulb.ac.be
Wed Oct 18 00:33:30 PDT 2017
Hello,
I’m using MapBender (which is a great tool, thanks a lot by the way!)
in Linux xenial with the last version of mapbender (3.0.6.3) and PHP 7.0.
but I noticed
that when I create a new application with those two following templates :
Layer classic & Full screen
I can’t see the map after adding the same WMS source (with the same
parameters) that I put in the other templates.
I wonder if it is a bug  or if I misunderstand something ?
Kind Regards,
Maë//e
N.B : I also would suggest to add in your documentation in “Preparation of
installation of necessary components listed” that you can install with
PHP5: the package libapache2-mod-php5
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20171018/6327f64e/attachment.html>
More information about the Mapbender_users mailing list
