[Mapbender-users] Mapbender don´t show map
Teresa Graßl
teresagrassl91 at gmail.com
Wed Sep 20 02:20:36 PDT 2017
Hello Jörg,
thank you for your fast response.
Yes, I did add the WMS to my layersets within the application and the
layersets to the map-element.
But they are not shown when I view the application. Do I have to consider
other configurations within mapbender?
Regards,
Teresa
2017-09-20 10:57 GMT+02:00 Jörg Thomsen (WhereGroup) <
joerg.thomsen at wheregroup.com>:
> Hello Teresa,
> I would do the first Mapbender-steps with a provided template, when you
> know what you are doing you can switch to your own template.
> Are the WMSs only added as a source? You also have to add them to a
> layerset within your application and add the Layerset to the map-element
> of your app.
> Regards, Jörg
> Am 20.09.2017 um 10:44 schrieb Teresa Graßl:
> > Hello,
> > I´m new in mapbender3 and can not show a map or any other elements in a
> > new application. I read through the mapbender documenation and tutorial,
> > but nothing worked.
> > I´m working on a Windows Server 2012 2R with WAPP (php, Apache,
> > PostgreSQL/PostGIS,..), Mapserver from MS4W and mapbender3.
> > My aim is to built a simple application with a map and points. My main
> > map should be the terrestris OSM (http://ows.terrestris.de/osm/service?)
> > and my points are saved as geodatabase in PostGIS. I can request my
> > point geometries as GetCapabilities and GetMap-Request. So MapServer is
> > working. Mapbender is working too, but if I include my database as WMS
> > or the terrestris WMS (as element main map), then they can not be loaded
> > (I can only see a white "map"-window). Unfortunetly no error massage is
> > shown. My points are saved as epsg:4326. The same I´m using in my
> > application. Both WMSs are defined and added in the sources. As Template
> > I used the pre-configurated Full Screen Template.
> > My problem is, that I´m not in programming or using php commands. I´ve
> > also tried to create a new template
> > (https://doc.mapbender3.org/de/book/templates.html) and follwed the
> > tutorial, but unfortunetly the tutorial uses linux-commands and for me
> > it didn´t worked.
> > Has anyone configurated mapbender3 on a windows server and created a new
> > application yet?
> > I´m very grateful about any advice or help!
> > Cheers
> > Teresa
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Viele Grüße,
> Jörg Thomsen
> INTERGEO 2017
> 26.-28. September 2017 in Berlin
> Treffen Sie die WhereGroup in Halle 3.1, Stand A3.053
> www.intergeo.de
> Jörg Thomsen
> WhereGroup GmbH & Co. KG
> Gillweg 3
> 14193 Berlin
> Germany
> Fon: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 89 09 53 21
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170920/140183be/attachment.html>
More information about the Mapbender_users
