[Mapbender-users] Error on loading mapBender
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Fri Aug 17 07:36:13 PDT 2018
Hello Marie Anna,
sounds like a problem I dealed with today. Has your WMS only a root
layer and no sublayers? That does not work at the moment, in the
capabilities MB needs a root layer with nested sub-layers, even if there
is only one layer in the wms.
> <Layer>
> <Title>Acme Corp. Map Server</Title>
> <CRS>CRS:84</CRS>
> <AuthorityURL name="DIF_ID">
> <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink...." />
> </AuthorityURL>
> <Layer>
> <Name>ROADS_RIVERS</Name>
> <Title>Roads and Rivers</Title>
> </Layer>
> </Layer>
(see http://portal.opengeospatial.org/files/?artifact_id=14416 page 80ff
for the whole xlm)
Workaround: save your capabilites as file, edit it to add the root-layer
arround your Layer and refer your edited xml when adding it as datasource.
Regards, Jörg
Am 17.08.2018 um 16:12 schrieb Marie Anna Baovola:
> Hello,
> Thank you for replying me.
> Actually, I use the v. 3.0.7.3.
> 1- When I tried to add a new WMS from my local laptop, I cannot load the
> map neither the scale. It shows me an error like "Your element with id
> map (widget mapbender.mbMap) failed to initialize properly".
> In addition to that, when I import a json files, I cannot load again the
> map and it shows me an error like "Legend image element (#14) couldn't
> not be itialized. No map - no legend."
> Thank you.
> Best regard,
> On Fri, Aug 17, 2018 at 2:52 PM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> Hi Marie Anna,
> Apparently you tried to include an image in your mail, but at least
> for me it does not pass the mailing list server. Could you possibly
> attach the image ?
> This said, screenshots are often no the best way to communicate
> about errors. Could you be more precise about what exactly you are
> trying to do, with what version of Mapbender and at what point
> exactly you see your error message ?
> Moritz
> On 16/08/18 12:58, Marie Anna Baovola wrote:> Hello,
> Anyone can help me how to fix this error when I load my page
> (new application or importation).
> The messsage shows "You element with id map (widget
> mapbender.mbMap) failed to initialize properly.
> Thank you.
> Best regards,
> BAOVOLA Marie Anna
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> <mailto:Mapbender_users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> <https://lists.osgeo.org/mailman/listinfo/mapbender_users>
> BAOVOLA Marie Anna
Viele Grüße,
Jörg Thomsen
FOSS Academy Sommerschule 2018
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen erlernen!
https://www.foss-academy.com/kompaktkurse
Jörg Thomsen
WhereGroup GmbH & Co. KG
Gillweg 3
14193 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 89 09 53 21
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the Mapbender_users
