[Mapbender-users] Remove Demo Applications
Astrid Emde astrid.emde at wheregroup.com
Thu Jul 5 11:18:14 PDT 2018
Hello,
the demo applications that you can't edit are created by yml-files that
are located in your installation at
mapbender/app/config/applications/
You only have to remove the files & clear you chache
or you can edit every yml-file and set "published: false" (so you could
use the application with the admin logged in but not everyone will bee
it)
Greetings Astrid
Am 2018-07-05 20:08, schrieb KirkN:
> I have installed and set up Mapbender and have made my own
> applications. I
> can't figure out how to remove the demo applications that show up on
> every
> user's screen. There usual edit and remove buttons are not shown. I am
> able
> to hide the built in YAML applications, but I don't see how to get rid
> of
> these demos. Can someone please give me a tip?
> I'm using Mapbender 3.0.6.3 on Ubuntu Linux 16.04.4 with the standard
> SQLite
> database.
> <http://osgeo-org.1560.x6.nabble.com/file/t383442/mapbender.png>
> Thanks
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Senior GIS-Consultant
AGIT 2018
4.- 6. Juli 2018 in Salzburg
Treffen Sie die WhereGroup bei der AGIT EXPO
http://www.agit.at/
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
