[Mapbender-users] Logo pro Anwendung
Axel Schaefer axel.schaefer at wheregroup.com
Thu Jul 12 01:10:57 PDT 2018
Hi
There is also a small workaround to display a logo in each application
and you need the CSS-Tab and a HTML-element.
You need a HTML element. Put that into your content at the first
position (above the map).
- Call that element "Logo" (see the CSS below).
- Place the following example into the content:
<a href="http://www.wheregroup.com" target="_blank"><img
src='https://www.wheregroup.com/sites/default/files/Prod_01_wg.png'
height='40px'> </a>
- Remove the Classes value.
Put the following in your css-tab:
| /* Logo */
| .logoContainer {
|   display: none;
| .mb-element-htmlelement[data-title='Logo']{
|   position: relative;
|   z-index: 10;
|   top: 10px;
|   left: 10px;
|   width: 260px;
This removes the Mapbender Logo (logoContainer) and places the created
HTML-Element with the data-title "Logo" at its place.
Regards.
Axel
david.mueller at kaiserslautern.de writes:
> Hallo Userliste,
> ist es möglich verschiedene Logos für verschiedene Anwendungen
> einzubinden? (Statt des allgemein gültigen Logos über die
> parameters.yml)
> Kann ich dies irgendwie über die CSS Eigenschaften des Logo-Containers
> steuern?
> Danke vorab für eure Hilfe!
More information about the Mapbender_users mailing list
