[Mapbender-users] search layer not visible on map/ nichtsichtbar
karsten
karsten at terragis.net
Fri Jun 22 01:36:28 PDT 2018
The no-show was indeed a projection problem. When I switched the map
projection everything worked fine. Also the search router provided
projection appears to be what the query view provides.
Now a follow up question comes to mind: in my project I have a Spatial
Reference System Selector with multiple entries. Given that the search
router does not reproject what would be a good solution to have the search
router still work when a user switches form the default projection?
My only idea was to come up with a PostGIS custom psql function that would
check the map projection and then accordingly reproject the search router
query ?
Any ideas what would work easiest?
Cheers
Karsten
-----Original Message-----
Sent: Friday, June 22, 2018 07:40
To: 'Mapbender User List'
Subject: RE: [Mapbender-users] search layer not visible on map/
nichtsichtbar
Hi Astrid,
>>> you should use the app_dev.php mode and inspect the results with
>>> F12. >>>
Ok will do.
>>> If I understand you right, you get a list of results listed in the
>>> SearchRouter, but when you klick on the result it is not shown in
>>> the map.>>>
Yes correct.
>>> Often it is a problem of projection. SearchRouter is not able to
>>> transform. So your SearchRouter has to provide the same projection
>>> as the application.>>>
Great advice. While I am not aware though where the search router projection
can be set/configured I guess that is the projection the geometry from the
postgis search view delivers. Is that assumption correct ?
Cheers
Karsten
Am 2018-06-21 21:05, schrieb karsten:
> Hi everyone,
> working with mapbender3 I have configured a search (Flurstücksuche
> with PostNAS data). Overall this is working as expected, however the
> search results are not shown on teh map as highlight layer. I already
> had this working at one point earlier in the project but don't know
> which change made this break.
> Would anyone have suggestions on how to debug this ?
> Cheers
> Karsten
> Hallo Allerseits,
> ich habe mit Mapbender3 eine Suche (Flurstücksuche mit PostNAS daten)
> konfiguriert die wie gewollt funktioniert. Allerdings erscheinen auf
> der Karte die Suchergebnisse nicht als Highlight Grafikebene. Ich
> hatte dies irgendwann einmal im projekt schon am laufen, weiß aber
> nicht welche Änderungen diese Funktionalität lahmgelegt haben kann.
> Weiß jemand wie ich das am besten debuggen kann ?
> Grüße
> Karsten
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Senior GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
