[Mapbender-users] Digitizer : different color for the objects
Gérald Salin gerald.salin at gmail.com
Sun Jun 24 14:26:47 PDT 2018
great, will try it asap!!!
thank you Astrid
2018-06-24 11:47 GMT+02:00 Astrid Emde <astrid.emde at wheregroup.com>:
> Hello Gérald,
> you can do this easily as you can use die OpenLayers 2 styles in the
> digitizer.
> See OpenLayer 2 styles documentation: http://docs.openlayers.org/lib
> rary/feature_styling.html
> You should add a new column for the color in your table, that you fill
> depending on the choice of the user.
> f.e.
> Alter table poi add column color varchar;
> As Mapbender does not support combo you could choose a selectbox  for the
> different types.
> Add the selectbox to your digitizer configuration:
> f.e.
>               type: select
>               title: Type
>               options:
>                 '#ff00ff': Type-A
>                 '#00ffff': Type-B
>                 '#ffff00': Type-C
>                 '#00ff00': Type-D
> Styles could look like this - with ${color} you refer to the new column
> with the color values
>   styles:
>     default:
>       strokeWidth: 2
>       strokeColor: '#0e6a9e'
>       fillColor: ${color}
>       fillOpacity: 1
>       fillWidth: 2
>       pointRadius: 10
>     select:
>       strokeWidth: 3
>       strokeColor: ${color}
>       fillOpacity: 0.7
>       pointRadius: 10
> Happy cycling!
> Astrid
> Am 2018-06-23 17:00, schrieb Gérald Salin:
>> Hi mapbender users,
>>  we (a french cyclist association, bicycle as a way of transport)
>> would like to use mapbender to allow cyclists to draw lines on a map
>> of the most important cyclable axes which they think is missing. We
>> are still evaluating mapbender. I already posted a message few weeks
>> ago and are still evaluate mapbender.
>> We would like to associate a type (combo with 3 items in the form) to
>> the lines added by the cyclists, and visually differentiate them on
>> the map.
>> do you know if there is a way to associate a color to each type so
>> that the lines appear differently on the map?
>> Thank you for your help
>> Gérald--
>> VelObs : remontez vos problèmes lors des déplacements à vélo sur
>> le web [1] ou sur android [2] (une appli 2P2R [3])
>> Pedibus labégeois [4]
>> Soutenez ICEA [5], Inititiative Citoyenne pour une Energie
>> Alternative, prenez ou offrez des parts sociales pour devenir
>> co-propriétaire de panneaux photovoltaïques
>> Consommez de l'énergie éléctrique verte renouvelable avec ENERCOOP
>> [6]
>> Links:
>> [1] https://velobs.2p2r.org/
>> [2]
>> https://play.google.com/store/apps/details?id=org.deuxpiedsd
>> euxroues.velobs.tlse&hl=fr
>> [3] https://2p2r.org/
>> [4] https://emilepattesblog.wordpress.com/
>> [5] http://icea-enr.fr/
>> [6] http://www.enercoop.fr/
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> Senior GIS-Consultant
> Aufwind durch Wissen!
> Qualifizierte Open-Source-Schulungen
> bei der www.foss-academy.com
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Eifelstraße 7
>  53119 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 22
>  Fax: +49(0)228 90 90 38 - 11
>  www.wheregroup.com
>  Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
VelObs : remontez vos problèmes lors des déplacements à vélo sur le web
<https://velobs.2p2r.org/> ou sur android
<https://play.google.com/store/apps/details?id=org.deuxpiedsdeuxroues.velobs.tlse&hl=fr>
(une
appli 2P2R <https://2p2r.org/>)
Pedibus labégeois <https://emilepattesblog.wordpress.com/>
Soutenez ICEA <http://icea-enr.fr/>, Inititiative Citoyenne pour une
Energie Alternative, prenez ou offrez des parts sociales pour devenir
<http://www.enercoop.fr/>
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20180624/a2205f85/attachment.html>
More information about the Mapbender_users mailing list
