[Mapbender-users] FeatureInfo Diagram
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Mon May 14 01:51:48 PDT 2018
Hello Jakob,
no, no static image, my suggestion was to create an image for each
request, e.g. with pChart. this would be the server-side-solution for
your js-idea with chart.js.
Anyway, it has to be implemented in the featureInfo-config of your WMS,
not in MB.
Regards, Jörg
Am 14.05.2018 um 08:46 schrieb Jakob Miksch:
> Hello,
> @Jörg: thanks for your useful response. If I understood correctly, your
> method would create a diagram as static image.
> I rather thought about having a dynamic diagram using Javascript. For
> example with Chart.js [1].
> Do you know if this is possible, has anyone done this already with
> MapBender?
> Best regards,
> Jakob
> [1] https://www.chartjs.org/
> On 2018-05-09 16:24, Jörg Thomsen (WhereGroup) wrote:
>> Hello Jakob,
>> Mapbender shows the FeatureInfo the wms delivers. So you would have to
>> create the diagram within your getfeatureinfo-request.
>> I would use a libary / script which can create the diagram on the fly
>> and use the call of the script as image-src (using mapserver...).
>> Something like
>> <img source='servername/diagramscript.php?objid=[oid]'>
>> regards, Jörg
>> Am 09.05.2018 um 15:13 schrieb Jakob Miksch:
>>> Dear List,
>>> I am currently evaluating MapBender for a project.
>>> I would like to have the functionality that the user clicks on a
>>> feature. Then the FeatureInfo-Box shall pop up and additionally a
>>> diagram based on the data of the feature shall be displayed.
>>> Do you know if this is possible? Has anyone done something similar with
>>> MapBender?
>>> Kind regards,
>>> Jakob
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Viele Grüße,
>> Jörg Thomsen
> *Jakob Miksch* | *Researcher*
> University of Salzburg | Department of Geoinformatics - Z_GIS
> Schillerstrasse 30 | 5020 Salzburg, Austria
> Phone: +43 (0)662 8044 7529
> E-mail: jakob.miksch at sbg.ac.at <mailto:jakob.miksch at sbg.ac.at> |
> http://www.zgis.at
Viele Grüße,
Jörg Thomsen
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
Jörg Thomsen
WhereGroup GmbH & Co. KG
Gillweg 3
14193 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 89 09 53 21
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the Mapbender_users
