[Mapbender-users] Bad credentials - Cannot login from client page
Axel Schaefer
axel.schaefer at wheregroup.com
Tue May 22 04:28:16 PDT 2018
Hi.
Several possibilities and a look in the logfile might help. Credentials
are in the parameters.yml. Check host and port (maybe 9.5 is on another
port), user and password. Check the pg_hba.conf for authorization
method. You can also check to go via psql to the database.
And as always: Clear the app/cache directory of mapbender (empty the
contents, not the directory itself).
Regards,
Axel
Marie Anna Baovola writes:
> Hello,
> I've had some problem with my PostgreSQL 10 before and now I reuse the old
> version 9.5. Actually, after getting the "500 Internal Server Error" I
> couldn't fix my problem so that I reinstall the package. Consequently, I
> cannot access to the application.
> It shows me error "Bad credentials", when I try to enter my login from the
> client page.
> Could you help me how to fix it?
> Thank you.
More information about the Mapbender_users
