[Mapbender-users] restrict use of digitizer to connected users?
Astrid Emde astrid.emde at wheregroup.com
Wed May 23 07:24:39 PDT 2018
Hello Gérald,
the functionality you asked for is not part of Mapbender yet.
We worked on this already and have a projects solution running.
If you are interested you can contact me at WhereGroup so we could work
on a solution for your project too and make the functionality ready for
next Mapbender version.
Astrid Emde
Am 2018-05-23 15:02, schrieb Gérald Salin:
> Hello,
> no idea about the feasability?
> Thank you
> Gérald
> 2018-05-18 20:02 GMT+02:00 Gérald Salin <gerald.salin at gmail.com>:
>> Hi,
>> I'm new to mapbender, I installed it on a test server, created an
>> app with digitizer enabled (postgresql + postgis). All is fine.
>> Thank you for this app!!
>> we (a french cyclist association, bicycle as a way of transport)
>> would like to use mapbender to allow cyclists to draw lines on a map
>> of the most important cyclable axes which they think is missing.
>> anyone accessing the frontend of the application can add lines on
>> the map with digitizer, but can also delete the lines of anyone
>> else....We would like a way of securing this editing.
>> Is there a way to allow only authenticated users to add lines,
>> delete or edit their own lines?
>> Thank you for your help
>> Gérald
>> VelObs : remontez vos problèmes lors des déplacements à vélo sur
>> le web [1] ou sur android [2] (une appli 2P2R [3])
>> Pedibus labégeois [4]
>> Soutenez ICEA [5], Inititiative Citoyenne pour une Energie
>> Alternative, prenez ou offrez des parts sociales pour devenir
>> co-propriétaire de panneaux photovoltaïques
>> Consommez de l'énergie éléctrique verte renouvelable avec
>> ENERCOOP [6]
> Consommez de l'énergie éléctrique verte renouvelable avec ENERCOOP
> [6]
> Links:
> [1] https://velobs.2p2r.org/
> [2]
> https://play.google.com/store/apps/details?id=org.deuxpiedsdeuxroues.velobs.tlse&hl=fr
> [3] https://2p2r.org/
> [4] https://emilepattesblog.wordpress.com/
> [5] http://icea-enr.fr/
> [6] http://www.enercoop.fr/
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Senior GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
