[Mapbender-users] restrict use of digitizer to connected users?
Gérald Salin
gerald.salin at gmail.com
Wed May 23 06:02:05 PDT 2018
Hello,
no idea about the feasability?
Thank you
Gérald
2018-05-18 20:02 GMT+02:00 Gérald Salin <gerald.salin at gmail.com>:
> Hi,
> I'm new to mapbender, I installed it on a test server, created an app with
> digitizer enabled (postgresql + postgis). All is fine. Thank you for this
> app!!
> we (a french cyclist association, bicycle as a way of transport) would
> like to use mapbender to allow cyclists to draw lines on a map of the most
> important cyclable axes which they think is missing.
> anyone accessing the frontend of the application can add lines on the map
> with digitizer, but can also delete the lines of anyone else....We would
> like a way of securing this editing.
> Is there a way to allow only authenticated users to add lines, delete or
> edit their own lines?
> Thank you for your help
> Gérald
> VelObs : remontez vos problèmes lors des déplacements à vélo sur le web
> <https://velobs.2p2r.org/> ou sur android
> <https://play.google.com/store/apps/details?id=org.deuxpiedsdeuxroues.velobs.tlse&hl=fr> (une
> appli 2P2R <https://2p2r.org/>)
> Pedibus labégeois <https://emilepattesblog.wordpress.com/>
> Soutenez ICEA <http://icea-enr.fr/>, Inititiative Citoyenne pour une
> Energie Alternative, prenez ou offrez des parts sociales pour devenir
> co-propriétaire de panneaux photovoltaïques
> Consommez de l'énergie éléctrique verte renouvelable avec ENERCOOP
> <http://www.enercoop.fr/>
(une
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20180523/307dd021/attachment.html>
More information about the Mapbender_users
