[Mapbender-users] Error on loading mapBender
Richard richard.jaeger at ba-pankow.berlin.de
Wed Oct 24 07:43:11 PDT 2018
Hello Astrid,
this is from the error-log of mapbender form updating the source of a QGIS
3.2 WMS:
> [2018-10-24 16:23:15] request.INFO: Matched route
> "mapbender_manager_repository_update".
> {"route_parameters":{"_controller":"Mapbender\\ManagerBundle\\Controller\\RepositoryController::updateAction","sourceId":"13","_route":"mapbender_manager_repository_update"},"request_uri":"XXX/mapbendertest/manager/repository/source/13/update"}
> [2018-10-24 16:23:15] security.DEBUG: Read existing security token from
> the session. {"key":"_security_secured_area"} []
> [2018-10-24 16:23:15] security.DEBUG: User was reloaded from a user
> provider.
> {"username":"root","provider":"Symfony\\Bridge\\Doctrine\\Security\\User\\EntityUserProvider"}
> [2018-10-24 16:23:15] security.DEBUG: No ACL found for the object
> identity. Voting to deny access. [] []
> [2018-10-24 16:23:15] app.DEBUG: CommonProxy->createBrowser rowUrl:Array (
> [scheme] => http     [host] => XYZ     [path] =>
> /cgi-bin2/qgis_mapserv.fcgi.exe )  [] []
> [2018-10-24 16:23:15] app.DEBUG: CommonProxy->handle
> GET:XYZ/cgi-bin2/qgis_mapserv.fcgi.exe?map=D%3A%2FGIS-Daten%2FStadt%2FStadt.qgs&request=GetCapabilities&service=WMS
> [2018-10-24 16:23:15] app.DEBUG: CommonProxy->handle Headers: Array (
> [User-Agent] => OWSProxy3 )  [] []
> [2018-10-24 16:23:41] app.ERROR:  failed to load external entity
> "http://www.w3.org/1999/xlink.xsd"  Element
> '{http://www.w3.org/2001/XMLSchema}import': Failed to locate a schema at
> location 'http://www.w3.org/1999/xlink.xsd'. Skipping the import.  Element
> '{http://www.w3.org/2001/XMLSchema}import': Skipping import of schema
> located at 'http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd'
> for the namespace 'http://www.opengis.net/wms', since this namespace was
> already imported with the schema located at
> 'file:///D:/ms4w/apps/mapbender3test/web/xmlschemas/http___www_opengis_net_wms_http___schemas_opengis_net_wms_1_3_0_capabilities_1_3_0_xsd'.
> Element '{http://www.w3.org/2001/XMLSchema}import': The XML document
> 'file:///C:/Windows/mapbender/xmlvalidator/XXX/cgi-bin2/qgis_mapserv.fcgi.exe'
> is not a schema document.  [] []
> [2018-10-24 16:23:41] app.WARNING: mb.wms.repository.parser.not_valid_xsd
> [2018-10-24 16:23:41] security.DEBUG: Stored the security token in the
Are there any changes in the QGIS-project-file necessary? Or in
qgis/bin/wms_metadata.xml?
Sent from: http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
More information about the Mapbender_users mailing list
