[Mapbender-users] Error on loading mapBender
Astrid Emde astrid.emde at wheregroup.com
Wed Oct 24 23:36:36 PDT 2018
Hello Richard,
thanks for the information.
Just another question. Can you load the WMS again via add Source with
only valid not checked?
Astrid
Am 2018-10-24 16:43, schrieb Richard:
> Hello Astrid,
> this is from the error-log of mapbender form updating the source of a
> QGIS
> 3.2 WMS:
>> [2018-10-24 16:23:15] request.INFO: Matched route
>> "mapbender_manager_repository_update".
>> {"route_parameters":{"_controller":"Mapbender\\ManagerBundle\\Controller\\RepositoryController::updateAction","sourceId":"13","_route":"mapbender_manager_repository_update"},"request_uri":"XXX/mapbendertest/manager/repository/source/13/update"}
>> [2018-10-24 16:23:15] security.DEBUG: Read existing security token
>> from
>> the session. {"key":"_security_secured_area"} []
>> [2018-10-24 16:23:15] security.DEBUG: User was reloaded from a user
>> provider.
>> {"username":"root","provider":"Symfony\\Bridge\\Doctrine\\Security\\User\\EntityUserProvider"}
>> [2018-10-24 16:23:15] security.DEBUG: No ACL found for the object
>> identity. Voting to deny access. [] []
>> [2018-10-24 16:23:15] app.DEBUG: CommonProxy->createBrowser
>> rowUrl:Array (
>> [scheme] => http     [host] => XYZ     [path] =>
>> /cgi-bin2/qgis_mapserv.fcgi.exe )  [] []
>> [2018-10-24 16:23:15] app.DEBUG: CommonProxy->handle
>> GET:XYZ/cgi-bin2/qgis_mapserv.fcgi.exe?map=D%3A%2FGIS-Daten%2FStadt%2FStadt.qgs&request=GetCapabilities&service=WMS
>> [2018-10-24 16:23:15] app.DEBUG: CommonProxy->handle Headers: Array (
>> [User-Agent] => OWSProxy3 )  [] []
>> [2018-10-24 16:23:41] app.ERROR:  failed to load external entity
>> "http://www.w3.org/1999/xlink.xsd"  Element
>> '{http://www.w3.org/2001/XMLSchema}import': Failed to locate a schema
>> at
>> location 'http://www.w3.org/1999/xlink.xsd'. Skipping the import.
>> Element
>> '{http://www.w3.org/2001/XMLSchema}import': Skipping import of schema
>> located at
>> 'http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd'
>> for the namespace 'http://www.opengis.net/wms', since this namespace
>> was
>> already imported with the schema located at
>> 'file:///D:/ms4w/apps/mapbender3test/web/xmlschemas/http___www_opengis_net_wms_http___schemas_opengis_net_wms_1_3_0_capabilities_1_3_0_xsd'.
>> Element '{http://www.w3.org/2001/XMLSchema}import': The XML document
>> 'file:///C:/Windows/mapbender/xmlvalidator/XXX/cgi-bin2/qgis_mapserv.fcgi.exe'
>> is not a schema document.  [] []
>> [2018-10-24 16:23:41] app.WARNING:
>> mb.wms.repository.parser.not_valid_xsd
>> [2018-10-24 16:23:41] security.DEBUG: Stored the security token in the
> Are there any changes in the QGIS-project-file necessary? Or in
> qgis/bin/wms_metadata.xml?
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Senior GIS-Consultant
Where2B Konferenz 2018
13. Dezember 2018 im Universitätsclub Bonn
Anmeldung & Infos: https://where2b-conference.com/
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
